I recently made a set of bus burs for my new front battery bank, and I was just wondering if anyone has any tips on polishing them?
I got steel wool, 1000 grit wet/dry paper, rubbing compound, and some Wenol all purpose metal polish.
I was told I just need to hit them with the steel wool, and then polish them up. So, is that it? Is there anything else, should I use a buffer, of just do it by hand? Do I let the polish dry, then buff it out? And what about wet sanding them, is that good a or bad idea?
All help is appreciated. Here are some pics of said bus bars...
Thanks again for your help!
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
dont wet sand, and follow instructions on the wenol tube, they are small enough that i wouldnt use a buffer. just some elbow grease
Okay, so just scrub them down with the steel wool then? And then hand polish with the wenol? Thanks for help.
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
X2 on just plain old elbow grease. A cutting compound followed by a polishing compound is great. I used to like Meguiars aluminum wheel polish. Mothers makes some too. If you have a vice, get those bars clamped so they are easier to work on. Good luck and pics with results please. Last time I polished aluminum was my CRF250 frame. I took it from a satin finish to mirror but it took a lot of time.
i would try the fine wool you have first, if there arent a bunch of deep scratches or anything sand those out with the sandpaper. but basically yeah, rub with the wool, then polish
these orphans aren't going to feast on themselves
  • Who's Online   0 Members, 0 Anonymous, 887 Guests (See full list)
