AI James Posted April 30, 2012 Report Posted April 30, 2012 whoever designed it failed then. while in the design stage he should have designed it correctly rather then needing 45s to take up space. It was bracing. they serve the same purpose as a squared dowel. i'm not the first to do it either, if you look at some of RAM designs pictures, he's put 45's in the sealed side too. it doesn't do any harm to have a little extra bracing in there. oh dont remind me of ram designs boxes lol using him as a defense is laughable.
stunt_az Posted April 30, 2012 Report Posted April 30, 2012 Those fi will be pimp 2001 Ford Expedition 2 SA 12's Crescendo 2000 M.E.C.A. 141.4 DB
412 CVX Posted April 30, 2012 Report Posted April 30, 2012 whoever designed it failed then. while in the design stage he should have designed it correctly rather then needing 45s to take up space. It was bracing. they serve the same purpose as a squared dowel. i'm not the first to do it either, if you look at some of RAM designs pictures, he's put 45's in the sealed side too. it doesn't do any harm to have a little extra bracing in there. oh dont remind me of ram designs boxes lol using him as a defense is laughable. Not using him as a defense. I'm saying the 45's were bracing. I don't see anything wrong with that. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
soundsystemaniac Posted April 30, 2012 Author Report Posted April 30, 2012 still some work that needs to be done, im going to get the plexi window and leds in today. and james, if all this fails, ill have you design me a ported box but so far, without being able to tune the amp properly, this box is doing well! Edit: obviously, the wiring will be all cleaned up. i was just anxious to hear this thing, so i made do with what i had around the house while i wait for my order from sonicelectronics to get here on friday. Chevy astro 2 18s and 9k rms Walled!http://www.stevemead...rms-42-inch-tv/JEEP GRAN CHEROKEE SRT8 BUILD!2 JL AUDIO 15s trunk buildDC XL 15 buildDC level 3 18 buildhttp://www.stevemead...verunner-build/ http://www.facebook....hp?id=646651228
AI James Posted April 30, 2012 Report Posted April 30, 2012 it will never fail if you dont know what it would sound like any other way
Ray Posted April 30, 2012 Report Posted April 30, 2012 Port looked smaller in first pic. Specs on the box? 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
soundsystemaniac Posted April 30, 2012 Author Report Posted April 30, 2012 it will never fail if you dont know what it would sound like any other way well, thats just it. i wanted to have something to go by. i have a 3.5 cu ft box tuned at 34 iirc, and i tossed it in there so that i would know what it would sound like otherwise. so far...my impressions are that the ported box plays lower, and louder, but the bandpass does not get play as low, but plays higher notes better. overall, the ported box did sound a bit louder. but im trying not to make any judgements until i get the hole cut in the seats and the seats up. i think that will help me a lot. also, i found out that the pos loc that i had in there was the reason that i had all the distortion. so i fixed that and now i have a clean signal and sound. Port looked smaller in first pic. Specs on the box? hold on, ill do the math on the box, but the port i know is 6.5 wide by 10.5 tall and 9 top depth and 13 bottom depth. Also, my voltage doesnt budge at all. still havent done the big 3 or alternator, but i placed the order on the alt a week ago. think i should see if its too late to cancel and refund? im a little confused on how the hell im sustaining this amp with some random interstate battery up front and just the 2 bt-60s in the trunk with 2 runs of 1/0 gauge, and i dont even loose a tenth of a volt at idle. what do you guys think about that^? Chevy astro 2 18s and 9k rms Walled!http://www.stevemead...rms-42-inch-tv/JEEP GRAN CHEROKEE SRT8 BUILD!2 JL AUDIO 15s trunk buildDC XL 15 buildDC level 3 18 buildhttp://www.stevemead...verunner-build/ http://www.facebook....hp?id=646651228
412 CVX Posted April 30, 2012 Report Posted April 30, 2012 if you want to tune lower you can make the port longer. Just say no to Ground Pounder Customs. My temp system build log More box buildssome cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches! I'm with captain stupid.
Ray Posted April 30, 2012 Report Posted April 30, 2012 Not really. Thats not how a 4th order works. 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
