Posted (edited)
hi, i just put in my 1st kinetik power cell to day, and i am havein some problems. i will do a run down of what i got and what i did when i put it in. and my problem.
96 ford explorer xlt
pioneer DEH head unit
2- pioneer 6x9 impp
2-pioneer 5x7 impp
4-ppi 2.5
JBL stock amp
2 12'' RE AUDIO SRX
PLANET AUDIO AP 1500D
KINETIK 600 HC
4 ga comp CADENCE AUDIO WIRE KIT
stock 130 amp alt
new batt in front but just a big cheap guy from advance auto parts.
so i have DB LINK 80 amp fuse/holders from my batt in front, then b4 the kinetik i have a 80amp fuse then i put a 80 amp from the kinetik to my amp. both batts and amp all have there own grounds.
so my problem is after like 2 mins of test time with the kinetik my fuse from the kinetik to my amp took a shit. im not sure why, i was thinking i need to move up in fuse size to a 100 amp, my amp is 90 amps but never blew a 80 amps fuse when runing on the batt in front. some help would be nice!!
Edited by sbg
01 focus se
110 amp alt
Big 3 sky high and stinger hpm ofc 1/0
Super start platinum AGM (starting)
2 runs of 1/0 Execution audio front to back
Kenwood double DIN DDx271
A pillars- orion 4" super tweeter and 2-1" alpines.
Orion xtx 64 in the front doors
2:1 4th order bandpass
Sealed off trunk
Digital designs deadener on roof/ rear deck
Orion hcca 12s (black coils)
Orion xtr3700.1
Orion xtr250.2 mid/highs
All sky high 1/0 in trunk dual runs(power/ground)
Sky high dual 1/0 inputs
2 xs power D3100 in back
Sky high batt blocks
Rose audio batt blocks
Stinger volt meter
All sky high 1\0 fuse and holders
Db link remote/ rca
just run a 150 amp ANL fuse and you should be fine. but think about upgrading your alt.
ya for sure its not doing good lol! i also have a POWERBASS ASA 1000.1 on 4 15'' audiobahns that i run from time to time. going to upgrade to 0 GA and do the big 3 but for now this is what i got.
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
do i have to run a fuse from my batt to the amp?
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Yes you should run a fuse between your battery and amp.It protects your amp if something goes wrong.
Vehicle
2007 Chevrolet Avalanche(Co-Co)
DNX9980HD
6 Team Fi 15's(King Edition)
3 DC 9k's
8 Nendo PWX 8's
4 Custom Steg 4" Super Tweeters
1 DC Audio 175.4
1 DC Audio 90.4
Rockford 360.3
3 DC Power 370xp Alts(Externally regulated)
21 D1600's
2 D4800's
All SMD RCA's
AudioTechnix Deadner
Viper Alarm
My YouTube- http://www.youtube.c...NG?feature=mhee
Link to buildlog- http://www.stevemead...4-15s-2-dc-9ks/
Link to UBL- http://www.stevemeadedesigns.com/board/topic/165059-ublkings-avalanchecoco-new-build-starting8-king-edition-15-team-fis-in-a-wallyes-a-wall/
the amp is 90 amps so fuse at 10 more amps then what the inline i put in, can the amp pull more then 90 amps?
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
i have 80 amp after the front batt like 10 '' from it then a 80 amp b4 the kinetik like 10'' from that 1. when i see people put a power cap in they dont fuse that and the power from that goes to the amp. why is that?
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
  • 4 weeks later...
fixed now runing 150 anl fuses
01 focus se
110 amp alt
Sealed off trunk
Orion xtr3700.1
Stinger volt meter
Db link remote/ rca
Another thing in your construction, if i understand it right, your rund a lead-acid batt (under the hood) and a AGM batt Kinetik 600.
The batt´s don´t like this.
"in the abundance of water, the fool is thirsty" Bob Marley
