I have a 2000 oldsmobile alero
recently ive been getting voltage drop at idle and low rpms drops down to about 14 volts at idle, hit the gas and it jumps back up to 14.7-15 volts.
It just started doing this and the weird thing is it only does it after the cars warmed up and at normal operating temperature.
i checked all my batts and there all good.
2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log
http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
Like he said, could be your alt going bad, just happened to me the other day on way to work, rpms dropped while driving twice, and then ran outta juice, take your alt out and get it tested at a local autozone or other parts store.
What's the problem? you are way above float charge so I don't get the issue.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Have you trained your bats to rest at that voltage?
and voltage fluctuates, the reason you see a lower voltage when the car is warm is because your batteries have been charged up after starting the car. If you see it sit in the LOW 13s and hesitate to climb you may have an issue.
-Drew
uhoh_45 said:
when my car is warm and I'm in drive at a stop light the RPMs are too low and the alt turns off, returns right back when it starts rolling
pretty normal operation
Yeh I understand this but something had to happened to just start happening after 2 years, sometimes when im slowing down it will flucuate like crazy.
Its always been at 14.5 at the.least no matter how hot or what rpms now im seeing 13.8 to 14.2 on average at idle, and its usually worse with a load like the ac.
put my stock alt back in and was much worse was dropping down to mid 12s as i slowed down so im rulling the alt out.
voltage is the same at the alt as the amps, and i have double checked all connections.
im pretty confused right about now :/ crappy voltage ftl
  • Who's Online   0 Members, 0 Anonymous, 530 Guests (See full list)
