Is it normal for the subs to get hot after playing them for over an hour?
2011 hhr (the milk truck)
Stock alt 130 amps
Big 3 1/0 gauge
Stock battery with shuriken sk-bt60
Brz 1700
Two skar vvx 12 in 4cuft box at 32hz
I want more!!!!!!!
Ok it has to be clipping the box was made by skar's builders
Stock alt 130 amps
Big 3 1/0 gauge
Brz 1700
I want more!!!!!!!
The sub getting warm is a side effect of normal operation and should be expected. If your woofer gets blazing hot, so hot you can't touch it or it smells that is not normal and you should adjust your gains to avoid clipping or only play in short burts and allow the equipment to cool before causing damage.
-Drew
uhoh_45 said:
I doubt it's the box at all. IMO its probably your amp. Giving it a clipped signal gets it warm pretty fast. How big is your amp? Chances are your really trying to push that sub (skars love power) and your pushing your amp to clipping.
98 Isuzu Rodeo
Pioneer Deh-6300ub
SUBS
​​*Upcoming* SSA Xcon 18 4th order
AMP
​Banda 3500
Mids/Highs
Pioneer
EQ
Clarion EQS746
ETC.
Two 1/0 run's
KnuKoncepts 1/0 big 3
Shuriken BT-100 under the hood
Shuriken BT-120 in the back
Power=heat. It's a misconception that clipping is the cause of warm woofers.
2007 M/T Honda Civic Coupe EX
(4) Sundown Audio X-8's
(2) Ampere Audio 3800.1's
(3) Stinger SPV-44 Batteries
(1) Mechman 240
3:1 Ratio 4th order sealed from the trunk
TEAM NWSPL
Best termlab scores to date in Honda trunk:
151.7db legal (official) IASCA trunk 3 class
Best termlab scores to date in my walled Subie:
152.9db legal (unofficial) IASCA advanced 2 class
155db outlaw
your going to get in so much trouble for that :]
09 Civic EX
KDC-X395
(2) SKAR Audio VVX-12
Skar Audio SK-1500.1
4 cu ft @32 (new box and more port soon)
Firing Forward not sealed off
Stock 80 Amp Alt
Big 3 In 1/0 Knu
2 Runs To The Back 1 Pos 1 Neg In 1/0 Knu
DD-1'd 13.8v drop
Kay, lemme rephrase that. Its a misconception that clipping is the ONLY cause of warm woofers,
(1) Mechman 240
TEAM NWSPL
155db outlaw
Well that's why companies incorporate cooling into the motor so it can handle more power do it will most likely get warm as drew (noobtastic) said
But it shouldn't get really hot. That would be caused by box error (which is pretty much ruled out for this situation) or clipping which creates unnecessary heat and more than the vc can handle=blown
I've gotten a blowjob and picked up my iphone behind her back to see what email notification I got from smd before
  • Who's Online   0 Members, 0 Anonymous, 1837 Guests (See full list)
