Problem: When I plug my phone into my charger and play music via an AUX cable, it makes a sound like static on a TV
Other info:
  • Does it when plugged into the charger only
  • Doesn't do it when plugged into the deck via USB (but this charges slow as sin)
  • Does it on multiple phones using multiple cables
  • 2010 Jeep Wrangler w/ factory gps
Ideas/fixes?
No fixes, the battery chargers for most phones use crappy insulation and being so close to your aux cable it just causes interference. May try a better aux cable or just charge your phone before you use it.
That is not a ground loop, just interference that FCC says you have to comply with lol.
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
Tried different cables, hell, I even put one of those ferrite rings around it. Even if I completely separate the 2 cables, it still makes the noise =/
And I get quite a bit of use out of my phone, so I kind of need a charger on top of nightly charging.
I wonder if you used a USB based charger and the AUX plug if it would still do it???
Evo X build log
What do you mean?
It makes the noise when plugged into my charger, but the stock deck has a USB charger too. It charges at a much slower rate, but doesn't make the static noise that my fast charger does.
Its electronic noise. You hear the charging "flow" of energy from the vehicle to phone. I can't escape it. Yet.
LOLZ, do what?
Evo X build log
What if I were to ground usb pin#4?
I dug up this article, seems like it worked for him as a musician. But this is slightly different, so might it work?
http://www.theworshipguitarist.com/blog/theworshipguitarist-experience/usb-ground-loop-noise-eliminated/
What do you mean?
Get a charger that plugs in and has a USB port in the back, use that since that doesn't make noise and use the AUX cable for the music, just a theory.
Evo X build log
  • Who's Online   0 Members, 0 Anonymous, 2803 Guests (See full list)
