Mine does the same thing. I just deal with it, but it would be nice to fix.
2009 Tahoe
2000bc Cresendo POWA Need 3500
2 Sundown Zv3 18 high rolled sexiness
dual alt bracket with Singer alt(coming soon)
Mtx Q(not sure if I'm going to use)
Knu wire and RCA's
Bass Head Bands
Oh and a few pairs of Jordan's
  • 3 weeks later...
Pull out the charging port, trace where it grounds. Replace the ground and relocate it. I had to do this on my peterbuilt. When I charged my ipod it had some nasty electrical noise it fed in. Moving the ground helped......in the end I bought another auxiliary outlet at Walmart and wired it direct to the battery with a fuse. That solved all the noise. Your issue is most likely caused because yours runs to your fuse box where all the electrical in your car gets routed. That is where the unshielded electrical noise comes from. Rewire your current one or add a new one. There about 10th bucks at Walmart and you can mount them anywhere.
I don't care if you can hear me from down the block....I just want to make sure you FEEL me from there...
I'm a swinger, can I borrow your wife for a few?
yea I just thought about it and the charger ground and head unit ground may be right next to each other, if not the same place.
My ipod charger would do the same thing when i used the aux plug.
Then again I have alternator noise to begin with, BUT this definitely made it worse. Let us know what you come up with.
Eclipse cd7000
  • Who's Online   0 Members, 0 Anonymous, 3076 Guests (See full list)
