DC Sound Lab
Stiff subwoofer pleasseee help!!!
Okay do I just got my subwoofer in and I have been trying to break it in but I guess I got a little reckless with it and it just cut out but i smelled the port and everything and and it doesn't smell or smoke like its blown but when I push on it it is SUPER stiff can someone please tell me what is wrong and if it's fixable. Please and thank you
Check coils...sounds like it blew.if its seized up coils came off former and are binding in pole gap...
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
This. If it wont budge when you press down on the cone, you have unwound the coil in the gap. This is caused by extreme clipping and heating up the coil so fast that the epoxy fails and the windings let go from the former. Oh and recones are cheaper than fixing a blown amp. But fishing all of that wire out of the gap is a royal pain in the ass.
  • Who's Online   1 Member, 0 Anonymous, 657 Guests (See full list)
