DC Sound Lab
Stiff subwoofer pleasseee help!!!
so i'm assuming i should just stick with 0db test tone
nothing lower than -10. if you play decaf or bigpimpin a lot, then -5.
alright thanks man. Like I said this is just a VERY painful learning experience.
it happens least you know now man
Check out my build log:
http://www.stevemead...60#entry1958353
Different folks have different strokes.
Hmm. Tune to -5db if I play decaf? Shit I tuned mine to 0db... will this be a problem for my sub?
no. 0db means you wont clip even if you play straight test tones.
of course playing music, your amp wont be clipping unless the music material is.
technically the safest tone recording volume to use for your amps
For beginners id use -5... first you need to learn your system and what songs are the loudest etc with your tuning...for example I can play airforces (42hz)fulltilt clipped for 30 secs and its the loudest in my hoe..subs will get really warm but not stinky..but if I play something tuned low (27)it will get stinky in 10 seconds..don't trip on recones bro..I've done the same thing..and burnt many more than I want to admit...
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Yeah now I'm kind of over it and just take it for what it is, a learning experience!
dont use with -15db, use the 0db/-5db
edit: f'n auto correct
Edited by ChevyBoy95
