DD1 and strapped amps
I did a search and none of the threads with these keywords helped so.
I have 2 bc5500's strapped atm. One of the threads said I should check both amps with the dd1.
On the amps when you strap you do + speaker to + of one amp and - speaker to + of second amp. Then jump the -'s of both amps together.
So when I check the second amp do I connect the dd1 to the - of the second amp since technically its the + or do I connect to the + of the second amp just like I would the first amp.
If that all makes sense. thanks for the help in advance.
Team B2
2008 scion xb bagged on 18's plastidipped matte black
4 18" b2 xc's pushed by 4 b2 m1s at .5 each
8 b2 hn6's and 2 b2 hntt's powered by 2 b2 quattros.
157.7 sealed so far.
you dont connect to the - speaker terminal when using the dd-1.
just the ground (chassis) and the speaker positive on the master amp iirc (because the other positive on the slave is essentially the negative).
Edited by ChevyBoy95
Well I know you dont use the ground on the dd1 on the speaker terminals.
But someone mentioned checking the second amp also so basiaclly do I put the red probe in the + or - of the second amp since they are strapped. And would I leave the jumpw wire in the amp also.
Team B2
Ok thanks. Was just checking cus I could have sworn someone said you had to check the second amp also.
Team B2
  • Who's Online   0 Members, 0 Anonymous, 1172 Guests (See full list)
