Can anyone guess what these will be used for ?
Nipple rings?
lol, No, way too small.
Any updates?
Should have some more work doen this weekend. Sorry for the delay, had to put rod and main bearings in my Denali - in my driveway.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
Started with one of these...
Took the lock washers off,
These things are hollow to allow the eyelet bolt to screw in and out.
Lets epoxy them to seal them shut!
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
dup post
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
First i coated the threads of the eyelet liberally with anti-seize lube (permatex item #80078). I put a good gob of the stuff on the tip.
Screwed them back into the base making sure to have a nice amount of lube still on the tip so the epoxy would stay separated (hopefully). Then I staged them inverted so they can be sealed.
Next i did standard equal parts and mix mix mix...I used a syringe for delivery.
Set out to dry.
At this point I really hope the epoxy doesn't penetrate or mix with the lube and make the eyelet a permanent fixture in the base. Let's come back in a few hours and check. 3 hours should be full cured. I'll give it like half of a day.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
I just made a video after they set for 12 hours. Will post after it uploads.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Test video - bear with me it's like 4 something in the morning.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Sorry folks, my wife has been sick and in the hospital recently so the project had to take the back burner. Got a little work done yesterday. Enjoy the pics.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Mounted the eyelets - just a 3/4" hole in a 4.5" piece of ply and some rtv. And a fiber washer on the top side for good measure. img20130421182448950.jpgimg20130421182452859.jpg
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
  • Who's Online   0 Members, 0 Anonymous, 1371 Guests (See full list)
