one thing I dont know if i like. The way you did your bracing. How far apart are they? Ive seen it where the flex causes the dowels to flex and then clack off each other. makes an ugly noise. I cant see if they are uber close like almost touching or if there is some space between them.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
All 3 braces touch the other 2 and are screwed and glued together. They will also be wrapped together in cloth and glassed.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
ok cool. glad you covered that already. didnt want to see you get it in and be pissed that they were clacking together.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
Thanks, I do appreciate you chiming in on it though. :drink40:
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Mother of god.. Those angles lol. What angle tool do you use?? I suck at angles man.. Looks amazing
My Truck Build
Spending money on things I don't need, to impress others I don't know.
At the end of the day for me its about the love of customizing anything and everything to limits or even past reasonable.-SkyHighCarAudio
Thanks man! I just use basic tools: square, speed square, mini battery powered circular saw and a table saw for the big and long cutts.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Fitting the box to the bed, sealing the bed cover and checking clearances.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Some reinforcements on the box.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Next steps:
  1. Drill Holes to bolt the box down
  2. Glue top to the box permanently
  3. Additional reinforcements in the box
  4. mount subs and test
  5. finish box (maybe some lighting, not sure if i wanna mess with that though...maybe)
  6. seal off bed from cab
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
  • Who's Online   0 Members, 0 Anonymous, 1098 Guests (See full list)
