No big surprise here but running at .25 ohm was clearly louder but also unstable. I wont be running .25 daily on this amp at all.
CURRENT SYSTEM:
  • Alternator:
    1. Stock alt on mids/highs
  • Batteries: (2) XS D1400s
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
  • Mids & Highs Amp: CT125.4
  • Active Components:
    • Mids RE XXX 6.5c
Build Log
Highest Legal Score: 151.0 db
if you had to do it over would you get different subs and if so what ones?
Alpine CDE-HD149BT Head Unit
Hertz HSK 165XL
Audison SR4 (Running the Hertz 6.5)
Audison SR2 (Running the Hertz Tweets)
Ascendant Audio Mayhems 4- 12" (Being Built)
DC 7.5K
230 AMP Singer ALT
6 XS-D3000 Batteries (Back) (In the works)
1-XS-D3400 Battery (Front)
Lots of SHCA Wire and Accessories.
I would but for different reasons. I could get more cone area from 12s cause I could use more of them considering the space limitiations in a mini truck cut-through. As for which ones....soo many to choose from, the Skar zvk looks interesting, Sundown's new lineup also. Always wanted to see what an RE XXX would do for me. Too many to chose from, I should have been born rich ;)
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Going to a small comp today to see what it does on the meter as a baseline. I've rewired to 1ohm cause .25 is just not stable enough and the amp gets hot quick. I may be clipping it but IDK without a scope or a DD1. Let's see what it this beast can do.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
  • 1 month later...
updates coming!
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
This build didnt get enough attention. Nice work
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
OK, so I was playing back at .25 ohm on a song way below tuning ...yeah....oops. It was nice sounding until the bass dropped even lower - instant smoke (Dynamix II - Release the Annihilator) Bass drops lower at about 1:01 in the vid. most of the track is a continuous tone.
So I shut it down quick but obvisouly too late. Amp smoked all to hell. That stink.... Amp still powers on to green but no sound. I pulled the cover and it has at least 3 burnt transistors.
I have nothing bad to say about the 4000d it did exactly what it was supposed to do. Sounded good dropped nicely. It blew because I pushed it way hard and was also playing below tuning. I will be sending the amp in for repair and I'll use it in another build or sell it.
Basically these subs need more power than the 4k could give it (really its about a 3k amp but does 4k at 16v).
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
So.....
I pulled the amp and RCAs to do some work:
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
BTW... the I blew the amp at the event I went to before I even got to meter it. Yeah it sucked but another guy there had a Ground Pounder 3000 he let me borrow to compete. I wasn't near as loud as the Soundstream but at least i got to go through the lanes.
138.5 30 second average on music
145.4 sealed on the dash
145.7 outlaw
No way to know for sure now but I 99.9% sure the 4000d would have metered much better.
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
Out with the old and in with the new:
Some 300a fuses, more 1/0, some 4ga, and fresh RCAs
CURRENT SYSTEM:
  • Alternator:
  • Headunit: 80-PRS
  • Sub Amp: DC 5.0k
    • Mids RE XXX 6.5c
Build Log
  • Who's Online   0 Members, 0 Anonymous, 1098 Guests (See full list)
