Deadly hertzz Posted April 29, 2012 Report Posted April 29, 2012 Ok I have 2 18 ssa icons in a 15 cu ft box tuned to 33hz Running off A Hifonics Brutus 2100 and 1 extra bat the meter was placed In the front corner of the window and I Was only hitting a 138 the way my Box Is In my car it looks walled off but just not sealed all the way around idk if its because the subs aren't broke in the mic position or what my amp is tuned in pretty good I hit 138 on music then 138 again on a 40hz tone help plzz I've seen ppl post way higher numbers with these suns also their in my 93 roadmaster Quote 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
WolfieGeez Posted April 30, 2012 Report Posted April 30, 2012 Ok I have 2 18 ssa icons in a 15 cu ft box tuned to 33hz Running off A Hifonics Brutus 2100 and 1 extra bat the meter was placed In the front corner of the window and I Was only hitting a 138 the way my Box Is In my car it looks walled off but just not sealed all the way around idk if its because the subs aren't broke in the mic position or what my amp is tuned in pretty good I hit 138 on music then 138 again on a 40hz tone help plzz I've seen ppl post way higher numbers with these suns also their in my 93 roadmaster Are they broken in? Because if not you'd probably loose a bit. Any fiberglass? 45 degree angles in the enclosure? How much port area do you have too? These are all factors that will affect your overall score. Sealing off the box from the rear is always good measure for increased pressure in the cabin, since now all the pressure will be in the front of the vehicle. Quote THE TC SYSTEM: >2003 Honda Civic DX coupe >1 TC Sounds TC-3000 1.4QVC >3cu ft 6" aeroport tuned to 30hz port⊂ forward facing sealed from trunk >US amps Xterminator XT-2000D (soon to go) >Pioneer DEH3000ib >Soundstream BX-20Z Digital Bass Processor >Knukonceptz 1/0 gauge wire >Knukonceptz 1/0 gauge wire big 3
SkateMike519 Posted April 30, 2012 Report Posted April 30, 2012 Ok I have 2 18 ssa icons in a 15 cu ft box tuned to 33hz Running off A Hifonics Brutus 2100 and 1 extra bat the meter was placed In the front corner of the window and I Was only hitting a 138 the way my Box Is In my car it looks walled off but just not sealed all the way around idk if its because the subs aren't broke in the mic position or what my amp is tuned in pretty good I hit 138 on music then 138 again on a 40hz tone help plzz I've seen ppl post way higher numbers with these suns also their in my 93 roadmaster Are they broken in? Because if not you'd probably loose a bit. Any fiberglass? 45 degree angles in the enclosure? How much port area do you have too? These are all factors that will affect your overall score. Sealing off the box from the rear is always good measure for increased pressure in the cabin, since now all the pressure will be in the front of the vehicle. Seal it!!! This should solve your problem. You should with ease be able to hit 148+. Quote 2 - Sundown Audio SA-12 D4 (Box tuned to 34 hrz) 1 - RF t1500.1bdcp 1 - RF t400.4 2 - JL Audio C5 5 1/4 in front doors 2 - JL Audio C5 570 in rear deck 2 - JL Audio ZR100 in front pillars 1 - Kenwood ExCelon HU
Toby Ratcliffe Posted April 30, 2012 Report Posted April 30, 2012 I would check to see if you are tuned properly. Check your voltage, gains, crossovers. Get clamped to make sure you are outputting the right amount of power, etc.... Then let someone look at your box, and find out where you are losing deebeezz. Quote
Robert8252 Posted April 30, 2012 Report Posted April 30, 2012 is this a TL score? Quote 2013 F150 Crew Cab Old Build Log Feedback 2013 F150 Equipment - Some Awesome Stereo Sound Making Stuff
Ram1989custom Posted April 30, 2012 Report Posted April 30, 2012 138? I would say seal it up like everybody else said. I can only imagine that should fix it. 138 is less than what my single 12 hits haha. Hope you figure it out! Quote 1989 Dodge D150, 318 LA; Holley Fuel InjectionBuild Log:http://www.stevemeadedesigns.com/board/topic/72838-dc-dodge-d150-blowthrough-thread-updated-pics-fixed-2-level-4-15s-wlvl-5-coils/Truck Add-ons: 20" rims2/4 drop15% tintBucket seatsK&N air filterSmog Pump deleteStereoWORK IN PROGRESS2 DC Level 4 15s with Level 5 Coils1 Audiopipe AP15001D (Soon to be a Crescendo BC3500)JBL 650W amp (unsure of model)4 6x9 Rockford Prime 3 ways2 Soundstream TWS.4 Dome tweetersKnuKonceptz 1/0 Power Wire *3 Kinetik 2400s and a Mechman 270A alt in the future*
Ray Posted April 30, 2012 Report Posted April 30, 2012 Lmao at 48 on 1800 watts. Good luck Some boxes dont do good sealed up. Does it get louder with a window down? Quote 2008 California state record holder 157.2 Bassrace2009 California state record holder 157.0 BassraceRollin 50's 158.7db2009 King of Cali Bassrace2009 USACi score 160.5 @ 42hz
WolfieGeez Posted April 30, 2012 Report Posted April 30, 2012 Lmao at 48 on 1800 watts. Good luck Some boxes dont do good sealed up. Does it get louder with a window down? Damnit beat me to that. Quote THE TC SYSTEM: >2003 Honda Civic DX coupe >1 TC Sounds TC-3000 1.4QVC >3cu ft 6" aeroport tuned to 30hz port⊂ forward facing sealed from trunk >US amps Xterminator XT-2000D (soon to go) >Pioneer DEH3000ib >Soundstream BX-20Z Digital Bass Processor >Knukonceptz 1/0 gauge wire >Knukonceptz 1/0 gauge wire big 3
Deadly hertzz Posted April 30, 2012 Author Report Posted April 30, 2012 (edited) No not broken in at all maybe week or two since the install I figured that would be a big factor and also im gonna seal it off b4 the next event and yes that's tl score an yes way louder with windows down an I set the gain by volt meter using a chart for the rms and ohm load to set to a certain voltage also I'm thinking about ordering an overdrive line driver should this help also? Edited April 30, 2012 by Deadly hertzz Quote 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
WolfieGeez Posted April 30, 2012 Report Posted April 30, 2012 No not broken in at all maybe week or two since the install I figured that would be a big factor and also im gonna seal it off b4 the next event and yes that's tl score an yes way louder with windows down an I set the gain by volt meter using a chart for the rms and ohm load to set to a certain voltage also I'm thinking about ordering an overdrive line driver should this help also? I'd say a line driver'd help. Last week I ordered and installed a Soundstream BX-20Z, which is pretty much the same thing, just with a 'bass restorer,' and the woofer is working MUCH less, but Its noticeably louder, and things are flexing much more. Really gotta get around to car reinforcement. Which by the way do you have any sort of reinforcement to keep down flex? Shouldn't affect your score too bad, but every little thing adds up. Line drivers/input voltage boosters are usually a must have. Also make sure your woofers are nice and broken in before seeking accurate peak readings. ;-) Quote THE TC SYSTEM: >2003 Honda Civic DX coupe >1 TC Sounds TC-3000 1.4QVC >3cu ft 6" aeroport tuned to 30hz port⊂ forward facing sealed from trunk >US amps Xterminator XT-2000D (soon to go) >Pioneer DEH3000ib >Soundstream BX-20Z Digital Bass Processor >Knukonceptz 1/0 gauge wire >Knukonceptz 1/0 gauge wire big 3
