I'm new to the box building stuff. I'm going to be building a box for a RE MX 18" D1. I'll be tunning it to aprox. 33 hz. I've heard of a lot of people building speaker boxes out of birch plywood. Would a mdf or a birch box be best??? :help:
MDF is cheap, easy to find and a little more forgiving to work with. birch is lighter but costs more.
i personally use birch for everything. I've been using it for years now and have no regrets. i don't miss MDF boogers at all
money isn't too much of a problem for once. its the time to build it. the sub came in an mdf crate and i practiced cutting a hole on it first. i burned through one whole bit to make that hole. will it be easier or harder to cut the birch???
birch if u got cash to spend. its lighter and withstands moisture better. IMO it sounds a little better. wont effect SPL tho.
hard to cut unless you got the right tools tho
NISSAN SKYLINE GTR R32 (Build in progress)Fosgate POWERhttp://www.stevemead...-fosgate-power/--------------------------------------------------------------------97 Honda AccordRockford Fosgate1400 watts RMS totalhttp://www.stevemead...e-1400watt-rms/---------------------------------------------------------------------
it like to peel and chip but if you got the right tools it wont be a problem
oh and birch is nice because you can stain it and make it look pretty =p for example my box is made of birch so i didnt have tp paint it
Lookn good. thats some quality work there!
I just used a cheap "Dremel" brand router i had to cut the circle. i could always cut 1/4 - 1/3 deep with the router, lower it a bit and go again..... cut it in layers and possible go through a couple of carbide bits.lol
Birch is 35-40pounds lighter a sheet than mdf, so you will save on gas money lol.
I didn't think it was that much difference in weight.... I thought it was about 10 lbs lighter per sheet?
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
either way.... its lighter. driving city all the time. im lucky to hit 16 mpg in my little car. i have 2 re 15s in there right now. it may end up costing me more but i think it is worth it. im going to give it a shot.... if the wife lets me :unsure:
  • Who's Online   0 Members, 0 Anonymous, 1468 Guests (See full list)
