OrionStang Posted April 30, 2012 Report Share Posted April 30, 2012 Don't NEED it, but it would definitely not hurt. Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
IBleedMusick Posted April 30, 2012 Author Report Share Posted April 30, 2012 Don't NEED it, but it would definitely not hurt. Okay I get it but for the time being I guess I will set em up the best way until I can get an external processor. Quote 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback Link to comment Share on other sites More sharing options...
OrionStang Posted April 30, 2012 Report Share Posted April 30, 2012 With those amps, you don't need the external crossover or a third amp. Put the tweeters(ch 1&2 hp) and midbass(ch 3&4 lp/bp) on one amp. Then, use ch 3&4 on the second amp for the 6's. Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
IBleedMusick Posted April 30, 2012 Author Report Share Posted April 30, 2012 With those amps, you don't need the external crossover or a third amp. Put the tweeters(ch 1&2 hp) and midbass(ch 3&4 lp/bp) on one amp. Then, use ch 3&4 on the second amp for the 6's. I think I understand but I will draw a model when I get home to make sure I get what you're saying. Quote 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback Link to comment Share on other sites More sharing options...
IBleedMusick Posted May 1, 2012 Author Report Share Posted May 1, 2012 (edited) With those amps, you don't need the external crossover or a third amp. Put the tweeters(ch 1&2 hp) and midbass(ch 3&4 lp/bp) on one amp. Then, use ch 3&4 on the second amp for the 6's. Okay Orion, last time I will annoy you but I want to be sure I have this right so I know what I am doing. Here is a pic of the amp: NOT MY PIC PULLED FROM GOOGLE AS A REFERENCE Amp 1 2 - Super Tweets 8 ohm Ch1/Ch2 - HPF LP/HP Freq - 3000hz Bass Boost - 0 Input Select - 4ch 2 - 6's - 4 ohm Ch3/Ch4 - LPF Band High Pass - 250Hz Low Pass - 3000Hz Bass Boost - 0 Amp 2 2 - Super Tweets - 8 ohm Ch1/Ch2 - HPF LP/HP Freq - 3000hz Bass Boost - 0 Input Select - 4ch 2 - 6's - 4 ohm Ch3/Ch4 - LPF Band High Pass - 250Hz Low Pass - 3000Hz Bass Boost - 0 Amp 3 I can get the 1.400 or 2.450 whichever would do a better job at playing the mid bass correctly. The 1.400 subsonic filter is 35hz and I haven't seen pics of the 2.450 but I would assume it has basically the same capabilities as the 4 channels or I can get at a third 4.600 if that is the best route. Edited May 1, 2012 by IBleedMusick Quote 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback Link to comment Share on other sites More sharing options...
Team Bassick - Kimo Posted May 1, 2012 Report Share Posted May 1, 2012 Love the dedication you got going there for speakers per channel per amp. where are your speaker locations? At this point you are probably better off doubling up your outputs especially since your 6's and tweeters are both using the same frequency. Lets be honest too your not looking at staging, height or imaging qualities with the amount of speakers you are putting in but, that thing will be loud. I'd recommend put the tweeters together and running 1/2 channel at 4ohms and then put the 6's together and running 3/4 channel at 2 ohms. you'll get more output of the amp and still have the correct crossover points per speakers. then you can use the second four channel bridged down or dedicated as a mid-bass amp. In my own set ups I use two 4channels to accomplish my 3-way setups. 1st set up tweeter to 1/2 4" to 3/4 6" to 1/2 rear to 3/4 2nd set up tweeter to 1/2 4" to 3/4 8" bridged to 1/2 & 3/4 Quote KIMO @teambassick http://www.teambassick.com Link to comment Share on other sites More sharing options...
Kyblack76 Posted May 1, 2012 Report Share Posted May 1, 2012 (edited) Excellent, and well done and well put. It can get a little weird. I'm active up front, with no where near the gear, and get lost at times.... Edit- O-stang, you help make those Sundown amps look really appealing for such projects as my amp pass runs only up to 500hz Edited May 1, 2012 by KyLar96 Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
Team Bassick - Kimo Posted May 1, 2012 Report Share Posted May 1, 2012 OH but, I also have a 701 processor for both three ways. Quote KIMO @teambassick http://www.teambassick.com Link to comment Share on other sites More sharing options...
Kyblack76 Posted May 1, 2012 Report Share Posted May 1, 2012 Lol, just an old 3sixty.2 here, no 3 way (god!, makes me unhappy in a few ways?) active with mine. And my amps only do so much... A bit of a battle trying the active VS passive on my end... But I'm giving it hell .. Quote SMD SUPER SELLER The Burban Build Blazer Build sold Acura trunk build sold Link to comment Share on other sites More sharing options...
IBleedMusick Posted May 1, 2012 Author Report Share Posted May 1, 2012 Love the dedication you got going there for speakers per channel per amp. where are your speaker locations? At this point you are probably better off doubling up your outputs especially since your 6's and tweeters are both using the same frequency. Lets be honest too your not looking at staging, height or imaging qualities with the amount of speakers you are putting in but, that thing will be loud. I'd recommend put the tweeters together and running 1/2 channel at 4ohms and then put the 6's together and running 3/4 channel at 2 ohms. you'll get more output of the amp and still have the correct crossover points per speakers. then you can use the second four channel bridged down or dedicated as a mid-bass amp. In my own set ups I use two 4channels to accomplish my 3-way setups. 1st set up tweeter to 1/2 4" to 3/4 6" to 1/2 rear to 3/4 2nd set up tweeter to 1/2 4" to 3/4 8" bridged to 1/2 & 3/4 If it will save me some money on buying a 4th amp I am all ears. So I will do 2 tweets on each 1/2 channel and 2 6's on each 3/4 channel and then use the 2nd amp for mid bass. So I should get 8 ohm 6's and 4 ohm 8's? How would I run one of the 8's off the 1/2 channel if it doesn't have the lpf band? As for imaging and staging considering I am a novice when it comes to the subject I would love to know where I should position each speaker. This is all going in a 2005 Honda Civic LX coupe I would love the best sound I can get instead of just installing them anywhere and calling it a day. My original plan was to atleast aim the tweet and 6 (on each door) towards the headrest of each seat and the back tweets and 6's would be by the arm rests for each respective passenger pointing towards the headrest as well. As for the 8's I wasn't sure on placement, they would either be sealed in the doors or sealed in the rear fill (since it is not currently being used at all). Any ideas and thanks again to everyone for all of the help, I am pretty much open to trying anything to get the best sound out of my car and I am always up to learn new things. Quote 2013 Dodge Charger Build Log 1996 Ford Explorer XLT 5.0Build Log 2005 Honda Civic LX Coupe Build Log SMD SUPER SELLER!!!!My Selling Feedback Link to comment Share on other sites More sharing options...
