i drive a '97 buick riviera 2 door coupe.
whats a reliable website for suicide door kits?
I'm getting my passenger door replaced within the next few weeks and have been wanting to get suicide doors on my car for a few years.
'08 Chevy Cobalt coupe 2.2 base model trunk build:
2 9512iSC flatwound alum 1.5 coils
-extra 9500 spider pack
-8" platinum carbon dustcaps
1 DD Z1 (.375ohm nominally daily)
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
4 VO-M8v1's (holes cut for 3rd pair)
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
all Knu Krystal RCA's
Cadence 7band EQ
______________________
148.3db @ 32hz (burp)
148.4 @ 37 & 38hz (burp)
146.xdb 90sec average (center windshield)
Actually not to sure that you have to buy a kit, because you have hinges and lock case already original. Only problem is to switch them.
No matter what you "Deicide" I'm tuned in for this thread!
Suicide doors on a 2 door? Not sure if I like that idea. To each their own I guess.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
can you try to expand on that?
sorry, always wanted them, but haven't put in a lot of research as to what i would need.
thats why i was just looking for an install ready sort of kit lol
can i ask why?
Edited by Robby Holmes
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
thank you ^_^
now to ask my father if he thinks this would be a fun project for us to do.
still want feedback from people though
3g31 AGM
320a Ohio Gen alt
1 DD S4 4 channel
2 CS 6.5's
2 VO-B1's
Sony XAV-601BT
Cadence 7band EQ
When I did Academy Sheet Metal years ago I tried suicide doors. Short story is to open the door and look at the place where the lock case is and measure the corresponding location with dimensions from the existing hinges and do the same as for the lock case and pin. I did however extend the hinge attachment of the body a little bit. I did the work in a "Dataliner" ( http://www.datalinerusa.com/ ) for easy measurement and because of the cars damaged bodywork.
Ofc it's easier to buy a new custom fitted kit, but I feel that some people almost forget they already got hinges and lock cases, but factory-fitted to the wrong end of the now new preferred. Nobody said it would be easy but if one can make the change with the cars own parts I think it's an opportunity to save money and also learn the basics and be even more proud of the result.
