adam43633 Posted May 1, 2012 Report Posted May 1, 2012 if i have 2 speakers next to each other can i run 1 speaker wire from my amp to the 1st speaker then have a jumper from 1st speaker to 2nd speaker so i don't have to run 2 speaker wires back to amp. would this affect how many watts each speaker is getting?
soundstream15 Posted May 1, 2012 Report Posted May 1, 2012 took me a few times to read your post to understand what you ment lol but ya its pretty much wiring subs inside the box. i dont see how it would effect it.
Tarball Posted May 1, 2012 Report Posted May 1, 2012 if i am reading this correctly then YES, wiring you speakers in Series vs Parrallel will present different loads to your amp. CURRENT SYSTEM: Alternator: Stock alt on mids/highs Isolated DC Power 270 SP - Charging @ 16.8v Batteries: (2) XS D1400s Power Cable: Double Runs of 1/0 KNU Kolossus Fleks Headunit: 80-PRS Sub Amp: DC 5.0k Subwoofers: 2 RE MT 15s /PSI dual .7ohm recones Subwoofer Enclosure: 9.1cubes @ 32hz - brutal. Mids & Highs Amp: CT125.4 Active Components: Mids RE XXX 6.5c Highs - 3 RE XXX tweeters per side(A pillar) Noise Control: Damplifier Pro all over the cab. Build Log If you do business with me please leave feedback here: FEEDBACK THREAD Highest Legal Score: 151.0 db Highest Musical 30 Second Average: 151.6 db
SmallTruk Posted May 2, 2012 Report Posted May 2, 2012 He wants to run a single wire then split it at the speakers to power each one instead of running two wires from the amp to each speaker, all in parallel from the sounds of it. So the load the amp sees will be the same with or without the second wire. I have a single run of 12ga speaker wire from the amp to the door then it splits into 2 16ga wires to each mid. That's what you're asking about, right?
