my so called sub ahah
cuetip
i havent bought the recone yet.. lol and i was watching a video of a21bravo reconing one of his fi btls, and he used some ducktape to get the stuff out, thats what i was saying about the tape trick lol
Tape trick is used as a last resort some have suck a tight gap you can't do that either
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
No you'll just have a hell of a time cleaning g the gap.
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Second Skin
Stinger
Tsunami Wiring
Sky High
lol ok i was just thinking that the recone kits are not that cheap so i was thinking about next week buying one until them getting it cleaned and looking right
compressed air works well if it has enough force behind it. Hell, when i did mine i blew into a straw and stuff flew out of the gap (on my XLs) and a bit of masking tap around the pole and it was spotless.
but N8 is right, tigher the gap, harder it will be. Luckily all my recone jobs have had huge gaps.
Yeah the tape is used first essentially as a way to block any small metal shards from getting down into the gap.
And your motor is fine, you just need to make sure it is all cleaned out and SPOTLESS before you drop the new coil in there.
In more sol oriented drivers you will notice a tighter gap, bigger gaps basically allow for more play which is what you want for music.
I'm not familiar with any DD drivers. And I'm on mobile so I can't look at the pictures of the gap as I type this. But just do your best and get that gap spotless before you drop in the recone. Or you will need to cut open your new recone to clean it out completely and buy ANOTHER recone. It's not the end of the world, common mistake if you haven't done a lot of research or asked questions first. Just learn from it, get her clean, and post more pictures when you finally start the reconing process. :)
On 6/30/2011 at 1:11 AM, 'Ray' said:
Acoustical energy is free. Electrical energy is not.
Looking at the pictures, it should be fun cleaning it out.
P.S. for grinding I've always just used a drill and a couple different sized wire brish attachments. I know other people have other preferences, but I used the drill on my first recone and it seemed to work fine, so I just stuck with it.
  • Who's Online   1 Member, 0 Anonymous, 1292 Guests (See full list)
