Deadly hertzz Posted May 2, 2012 Report Posted May 2, 2012 I Just ordered an audio control overdrive plus I used this chart http://img519.imageshack.us/img519/5993/rmschartpm5.jpg. To set my amps gain after installing the line driver would I have to go back with the Meter and adjust the gain on the amp again or would it not affect it 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
getlocivic Posted May 2, 2012 Report Posted May 2, 2012 it gives more rca singal so yes amps will produce more power at lower gain levels going from say 2v preouts to 4 or 5v is a big difference
jrchevy87 Posted May 2, 2012 Report Posted May 2, 2012 yes you will have to readjust your gain as the line driver boosts the rca voltage and will make you amp clip very quickly if you keep you gains set to where they are now Jeep Wrangler TJ Hardtop Build
Deadly hertzz Posted May 2, 2012 Author Report Posted May 2, 2012 Iite just making sure ill b sure to Do it thanks every1 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
ALPINE408 Posted May 2, 2012 Report Posted May 2, 2012 gain is to match output voltage to imput voltage so if you up the input voltage will have to lower your gain...... gain is not a volume knob Have you ever had your woofers blown?
Deadly hertzz Posted May 4, 2012 Author Report Posted May 4, 2012 Yeh I understand I set it Right when I installed it I was just makin sure after the line driver to readjust it 8 sundown sa 12s walledSaz3000 at .5HO altAll ofc Sky high wireAlpine componentsRockford power mids
