Walling A Mustang
Sweggy
im goin to start a wall in my mustang im wonting to do it for 3 15" subs. it will be for SPL/daily driver but more for SPL. any advice on this build.or will it even be possible to put 3 15" in a wall in a mustang. any help or advice will be greatly appreciated. thanks guys
well wut do you think about 2 18's and if i went with 2 15 wut subs would you reccomend because i was goin to go with the 3 opti1535d and 3 opti2000d
well what do you mean by spl. are you willing to have the driver seat all the way forward? and loose all trunk space for amps and batts ? if so , the box depends on the 15s you go with and all , but you can build a wall that has a few inches in the floor board and then goes up and then along the seat of the rear and have it go from side to side and from floor board to 2-3 inches from roof, seal the sides up with 1.4 mdf or fiber board and back fill with foam, spray paint the windows black so noone can see in and you dont see the bare wood, window tint will work but with the box sealing up the space the heat will build up and eventualy fall off *it might not but then again it mostlikley will* and if you remove the box a razor will remove the black paint just as well as remove tint. but the paint wont fall off and noone will see in.... and if you feel brave enough you can completly cut out the rear dash and back seat back rest and have the box go back a little further into the trunk ..... just a few ideas
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
i hope you didnt scare him away from his wall build?
yea i was goin to use the trunk for amps and batteries anyway and yea im willing to have the seat up but not so far up i cant drive it.
:lol: lol might as well be upfront instead of beating around the bush, a tang can be done i bet i could make 4 15s or 18s go in one but it would be a nasty daily driver with poor gas mileage due to the weight lol with alum blocks in place to keep the body off the tires .... but it can be done he just has to be willing to destroy the car to do it :P its a small price to pay to be loud, but then on the other hand he will be safer with that wall in place , if he gets hit in the side the box might save his life (wont mention the bad that can happen) lets look on the brighter side lol< and if he happend to be going around a steep and sharp bend down a mountan and ran off a clif the box if built properly could give him a cussion that could save his life , meaning that if landed on the roof the box might not complety cave in and give him a small pocket of seat area to crouch down into... lol
nice way to keep me from being bored thinking of little things lol
now that wigglez has prolly scared u away from a wall ill suggest sumthin
the 2 15's u want are DD 9915 or 9515
these woofers are very loud and very expensive but like i said VERY LOUD
to get ur car to be perfect itll take alot of work and money
i hope your prepared for that
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 1800 Guests (See full list)
