Chaosgrunt Posted May 3, 2012 Report Share Posted May 3, 2012 K so I'm just gonna run everything by you guys to double check. I should be set to start building next weekend! Subs: 3 AudioQue hdc4 18's Amps: 3 AudioQue 3500's @ .5 ohms Enclosure: 18 cubes after displacement, 324 sq inches of port @ 30hz tuning. Electrical: 3 320 amp alternators and 6 xs power d3100's. Gonna start the build log next Friday building the box but the subs and amps wont be here for another month or so. It will be a slow build log but oh well. I only make so much money lol. Quote Link to comment Share on other sites More sharing options...
BassJunkie Posted May 3, 2012 Report Share Posted May 3, 2012 Sounds good! Now get to work and post a build log What vehicle? Quote 1986 C20 Suburban 9 American Bass XFL 15's B2 M1MKII 14v XS Power Batteries Maxwell Caps Acoustical energy is free. Electrical energy is not you havent lived until you've hit a screw with a router. Link to comment Share on other sites More sharing options...
Chaosgrunt Posted May 3, 2012 Author Report Share Posted May 3, 2012 Sounds good! Now get to work and post a build log What vehicle? Its an 01 mustang =) Quote Link to comment Share on other sites More sharing options...
727Designs Posted May 3, 2012 Report Share Posted May 3, 2012 Good luck fitting 3 18's, from what I've seen on Mustang wall builds it's tight to do 2. Quote -Zach-2010 Toyota TundraFull Hybrid Audio SQ 7" BDS on 37's 2000 Ford Expedition 160+ dB Green Turd -SOLD- Link to comment Share on other sites More sharing options...
Chaosgrunt Posted May 3, 2012 Author Report Share Posted May 3, 2012 Good luck fitting 3 18's, from what I've seen on Mustang wall builds it's tight to do 2. Yeah its a tight fit doing 3 but possible. Couple people have done it before. Quote Link to comment Share on other sites More sharing options...
OrionStang Posted May 3, 2012 Report Share Posted May 3, 2012 3 Warden 18s 2004 mustang - SMD Forum Have fun with that. Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
Chaosgrunt Posted May 3, 2012 Author Report Share Posted May 3, 2012 3 Warden 18s 2004 mustang - SMD Forum Have fun with that. Yep that's one of em. I read your whole build log a couple days ago and so I said screw it ill wall mine too. Quote Link to comment Share on other sites More sharing options...
Chaosgrunt Posted May 3, 2012 Author Report Share Posted May 3, 2012 (edited) Also, it will be nice doing a huge build like this because I have nothing to rush for. I wont have the subs for a month so I can spend that whole month making a nice box. Even painting it and making it look good. Edit: oh and fiberglassing components onto the 3rd baffle. Edited May 3, 2012 by Chaosgrunt Quote Link to comment Share on other sites More sharing options...
OrionStang Posted May 3, 2012 Report Share Posted May 3, 2012 IMO, 2 will louder than 3. UNLESS you cut out your entire rear deck to build the box big enough. You need 16.5 cubes 'minimum' after all displacements. That dude was running 2 amps per sub strapped at .35ohms with a smaller than ideal box. Quote SMD Super Seller My Feedback Thread Link to comment Share on other sites More sharing options...
Chaosgrunt Posted May 3, 2012 Author Report Share Posted May 3, 2012 (edited) IMO, 2 will louder than 3. UNLESS you cut out your entire rear deck to build the box big enough. You need 16.5 cubes 'minimum' after all displacements. That dude was running 2 amps per sub strapped at .35ohms with a smaller than ideal box. Yes I will be cutting out the rear deck and then reinforcing the rear. Edited May 3, 2012 by Chaosgrunt Quote Link to comment Share on other sites More sharing options...
