Next step: Double DIN headunit install.
So it may look like E46 Bimmer's are already set up for a double DIN but that would be a big negative.
Pulling the HU out and you find this...
Double DIN face but.........a single DIN body. :glare:
Here you can see why:
There is an air duct in the way that the HU must fit around.
In order to make a double DIN fit, some involved fab work is involved.
Here's a close-up:
No going back now...first cuts to the air duct.
Inside the air duct is a vent door with a connecting rod to another door on the other side.
This door actually swings in the way of the double DIN bracket and must be cut in half.
Here is the vent door that has been removed and cut in half.
So the small piece of the door needed to be glued back in place while the bigger piece rotates.
The door has some soft rubber around it and wouldn't glue very well. So I ended up taking some bulk plastic that I bought from Parts Express
and cut out a replica that would glue much easier.
Here's the small piece I made glued in.
The connecting rod between vent doors gets in the way and needs to be notched.
The kit I got from eBay included a small metal offset to do this but it wasn't strong enough to handle the pressure (the small little screws would easily pop out of the plastic), so I pulled out the trusty JB Weld and epoxied that sucker. Looks like shit, but she's STRONG now!
Adding weatherstripping around the opening to help seal it.
Bracket installed in the cutout. I added some spare Alpha-Damp to the bracket as insulation since the air duct gets pretty warm with the heat on and I didn't want it to degrade any of the wires behind the HU.
More headaches.... :aggressive: The double DIN bracket I got had rounded edges and didn't fully seat the HU.
This wouldn't allow the HU to properly sit inside the bezel.
Ok PITA bracket, meet my new friend, Mr Sledge!
I had to cut the welds and break off the side braces.
JB Weld to the rescue...again.
That's better:
After a some struggle, I wedged the HU in place and it fits! :drink40:
More pics coming. I don't have all the trim back in place yet because I still have work to do with the center console.
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
dang looks good so far! Love the euros with a clean and loud system!
2003 VW Jetta Wagon AA Mayhem 15's Flatline BA2 2 XS D3100's in rear Shuriken BT80 under hood
Mike Singer 250A SHCA and KnuKonceptz wire Big 4+
AQ / Dayton pro mids+monsoon tweets
My Build : http://www.stevemead...35#entry1989435
Thanks! I agree.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
Door speaker update:
After looking around the forum for a while and hearing great things about them, I pulled the trigger on some Hertz HSK130's.
I played it safe initially with the 5.25" mids which only required a small mounting bracket that I got from Crutchfield.
Made the install really simple. The brackets interfaced perfectly with the goofy three-tab factory speakers.
We'll see how I like these before I tackle a custom door pod.
One of the door panels removed and partially gutted:
One of the mids installed with the interface bracket.
Tweeter inside one of the included mounting brackets.
Mounted to the stock tweeter location.
Fits nice with not too much modification.
Wires run to the tweet/mid.
The blue wire is 12ga Knu Kord. Input to the x-over is also Kord.
Clear wire is 14ga speaker wire from Part Express. They had a sale, $9 for 50'. Not as flexible as the Kord but it gets the job done and is plenty for the tweeter.
Custom mounted the x-over to the inside of the door panel.
The door panel itself was too thin to put screws through it so I cut some bulk 1/8" plastic to the same size and epoxied it to the panel.
Gave me just enough thickness to screw the x-over down nice and snug.
Here's the completed door panel.
Added some AlphaDamp to the door panel to secure the wires.
This is the Kord from the highs amp to the x-over input.
Ran through a grommet in the car body and into the stock wire harness for the doors.
The panels are clipped back on the doors but not fully screwed in place. I want to hear the Hertz's first in case I need to pull the panels off again.
It is nice to have door panels again! I drove around for a few weeks with no drivers-side door panel. Was a pain yanking on the door opening cable to get out of the car...
Side-note: I started the box build this past weekend... :drink40:
Feels good to be cutting some MDF again after about 6 years.
Everything's coming together nicely and should be pretty sweet when all completed, I have some ideas brewing.
Stay tuned, I have more pics coming before I can get to the sub box!
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
Nice work fitting the double din in there. That's determination.
Thanks!
No kidding... :trippy:
Don't know that I'd try that again now that I know what it takes.
..something about stuffing 10lbs of shit in a 5lb bag. :lol:
Fingers are crossed that I won't ever have to pull it back out...
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
you didnt ebay the hertz did you? mucho fakes out there.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
No Sir, but it was tempting...
I saw a few threads about it between Ray and Orionstang and figured I'd better play it safe and tracked down an authorized dealer here.
Cost quite a bit more but they are legit and should be fully warrantied.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
whew. they are very close looking and not so close sounding. nice work .
Alpine CDA-9887
4 Team Fi 15s
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
Thanks :drink40:
Somewhat torturous though with them sitting in my doors staring at me with no amps connected yet cuz I'm still in the process of building out my trunk..... <_<
The speakers on my iPhone really ain't cuttin' it........
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
  • Who's Online   0 Members, 1 Anonymous, 1820 Guests (See full list)
