Interested to see where you go with the volt meter/bass knob.
The E46 M3 is probably my favorite BMW to date.
2016 Subaru BRZ | Sony XAV-AX100 | Rockford Fosgate DSM 4080 & DSM 40ix |
On 6/6/2012 at 6:32 PM, 'LZTYBRN' said:
3. Don't put speakers outside the car unless you are the ice cream man.
My feedback thread
Mine too, favorite car that I've owned/driven by far.
Yeah, hopefully my little fabrication project works out.
Been busy on the box lately so not much progress on that yet...
This post sent with 100% recycled electrons.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
500F of Maxwell SuperCaps (soon to be 1000F)
iPadMini2
Dash mounted O-scope
Audison bitOne (Remote DRC MP)
Highs Amp - PPI Art A404
Hertz HSK130 (HSK165 waiting...)
DC Audio DC9.0K
2- DC Audio XL12m2
LEGAL             - 147.3dB @ 41Hz
OUTLAW         - 150.2dB @ 45Hz
OUTLAW         - 145.7dB @ 30Hz
JUNE 2014 SOTM WINNER
2014 COLORADO PEOPLE'S CHOICE WINNER
SOTM BUILD:
http://www.stevemeadedesigns.com/board/topic/141656-wicks-e46-m3-build-bass-turbo-button-and-a-big-new-addition/page-68#entry2802026
Anybody have experience with Bluetooth mics?
I really didn't want to tear apart my A-pillars to run a microphone up to the overhead console.
So I found a neat spot on my center console that I figured would work just as good and be stealthy.
I drilled a hole near the cig lighter
Then mounted the mic right behind the hole.
Looks alright and you'd never notice it if it wasn't pointed out.
Although a tried a call with it and the sound was all muffled and didn't work very well... :aggressive:
Ohhhh well.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
On with the build.
Used the spiral-saw to cut out the port openings on the top cover of the box.
Of course had to do some roundovers on the underside to help airflow.
Here we go! First panel to be glued together (in the car only). :clapping:
Then the baffle (the side not clamped is just there for alignment).
While that was gluing, I went to glue the top cover to the port assembly (again making great use of my stock battery)
Later on in the build you'll see why I wish I had better 90degree bracing on these pieces... :Doh:
While more glue is drying, I drilled some holes in my plexi for the rear panel. Being again cautious, I used my hole jig to make them as straight as possible.
To keep the holes identical, I drilled through the plexi and rear panel at the same time.
Threaded inserts added to the rear panel, to allow easy removal of plexi should I need to (swapping subs, changing wiring, etc)
Ninja pic :ph34r:
Before I could glue down the right side piece, I needed to fab this bracket and get it attached to the frame cuz I wouldn't have easy access once the box was fully assembled.
More on that later...
Right side glued
Using a wedge to apply downward pressure on the panel. I didn't like how the pocket hole screws were working so I stopped using them. They tended to either slide the piece out of flush or causes a gap between pieces.
Front view
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
FML...
I have more pics to post up but the build is on hold for the moment.
I woke up to this this today :shok:
Any VANOS guys out there are probably familiar with this.......
Time to see what my extended warranty is made of.
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
FML...
it's a familiar sight too me...
had an e36 2.5i 24v vanos
same problem... at the dealer they said that it couldn't take the power the engine has...
i'm very sorry to see this cuz this will be a huge gap in your budget
FML...
What are we looking at? Valve cover???
-= J-dUb =-
....no 12 step program can cure my car audio addiction...
FML...
Yep, valve cover right over the timing chain.
She's on the tow truck as I type this.......
2004 BMW M3
Mechman 280A
2 - XS Power XP3000
1 - XS Power D375
iPadMini2
DC Audio DC9.0K
2- DC Audio XL12m2
SOTM BUILD:
FML...
you must be sick of heartake now aren't you?
seeïng it pull away at a towtruck...
you got some bigg spending to do now
hey but know what? you got some mental support from belgium ;)
felling your pain cuz i know what you're going thru now
peace
  • Who's Online   1 Member, 0 Anonymous, 933 Guests (See full list)
