Fml. I blew a head gasket today on my way home and now I'm looking for good replacement. Current gasket was only about 5 months old before it gave out again. - _ -
So my question is: Does anybody have any suggestions to possibly the best replacement gasket for this engine? And how to choose one?(bore size, etc.)
Thanks in advance.
CHECK OUT MY MYSPACE; SOME PAINT WORK I'VE DONE: http://www.myspace.c...customcreationz
DODGE RAM 1500 QUAD CAB BOX BUILD: http://www.stevemead...showtopic=48978
DODGE RAM 1500 RUMBLEBEE EDITION CUSTOM ENCLOSURE: http://www.stevemead...showtopic=48983
PREFAB REMODELING: http://www.stevemead...box-remodeling/
G35 CUSTOM PAINTED L7 BOX: http://www.stevemead...om-painted-box/
CHEVY SINGLE CAB PAINTED SUB BOX/AMP RACK: http://www.stevemead...vy-boxamp-rack/
KICKER L512 BOX BUILT TO SPECS: http://www.stevemead...-kicker-l5-box/
RF HE2 10'S KERF PORTED BOX: http://www.stevemead...erf-ported-box/
2 DC LEVEL 3 15'S KERF ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/115502-kerf-ported-enclosure/
2 HCCA 15'S PORTED ENCLOSURE: http://www.stevemeadedesigns.com/board/topic/129468-2-hcca-15s-enclosure/
if you put a HG on 5 months ago i would question why it blew. Something has to be wrong. warped deck surface and or head,bad tune,improper torque and or sequence something is going on i assure you! the best gasket hands down is a muti layered steel felpro perma torque. I have seen them used to 90 psi in boosted drag engines. Many world record cars run them. Just remember if the gasket holds and there is a underlying problem you may end up with broken/melted pistons,rod through your block etc..
glad to see you made it to the forum.. i had a feeling you would chime in on this. there are some real knee slappers that happen in this sub forum.. so be prepared.
yeah head gaskets dont just blow for no reason. Have you heads checked to make sure they are flat as well as your block deck surface.
2012 Toyota 4Runner Trail Edition-Singer 240A Alt, Odyssey Battery,Pioneer AVH-2550NEX head-unit, Pioneer GM-DX874 powering Kicker CSS67 front-CSC5 rear, and Memphis PR 1.1000 powering 12in SSA ICON in G.P. ported box.
2003 Tahoe-320A Alt, Odyssey Batt,2 Resilient Sounds Gold 15's sealed powered by Crescendo BC2000D, Turbulent Designs Ported box AVH601EX head unit and Pioneer 3ways in all doors.
Everything was done properly when we had the heads rebuilt 5 months ago. I'm guessing it blew because the thermostat failed to open & I do a lot of towing/heavy hauling/aggresive driving.
if your gasket popped from an overheat you now have a warped surface and need the head milled and the block decked
Ok, thanks for the response, I'll be looking into that this week since I already ordered new head gaskets.
New thermostat to. Put a straight edge on the deck surface when you get the heads off to make sure the deck is flat. Heads to.it blew for some reason. You'd have to get it way hot to warp enough to blow it.
Took the thermostat off since it wasn't opening. I took the block to the machine shop & it wasn't warped. I also got the heads resurfaced.
So you think the thermostat malfunctioned and the motor overheated?
Big 3 with Yellow Top
I'm guessing so because when I pulled over to check the engine the day the gasket blew after seeing steam coming out from under the hood, the hose going from the radiator to the thermostat housing was inflated.
