8,000 watt+ walled 2door car (new doors 20 mids/highs)
started glassing
started working on my new amp rack i just had the 3500s on there to make sure it would all fit
the 3500s are actually going to be on top , the bottom will be a kicker 450.2, kicker kx3 crossover, hifonics 2000.4, and fuses and other misc. stuff
2 fi btl 18s on 2 crescendo 3500s walled in a 2dr 2000 alero build log
http://www.stevemeadedesigns.com/board/topic/141663-2-walled-btls-18-on-7k-in-a-2000-2dr-alero/
how low ur voltage drops ? with 250 alt and 5 batts ...
and did you upgrade ur suspension ?
sometimes Loud is NOT pretty
Sounds like its safe to go ahead and bend that ass over.
I actually have 7 batteries. theres 6 in back one up front. If i have been bumping for a while demoing and what not it will drop into the 11s, usually just mid low 12s though. I am probally gonna add some more batteries if i cant get my dual alt setup done
no suspension upgrades yet . i have spring stretchers on for now .
seems the only thing i can do for my car is to get custom springs made to restore the ride height. or bag it which is out of the question.
get those springs before it gets worse!
and what batts are you using?
Team Clearly Louder (MECA)Team DC Audio
++* SELLING the CACTUS SOUNDS K12 for $1550 shipped *++
HMU!!!
3 flips. nollie flips. big flips. hardflips. - steez
Youtube Channel My Build Log
95 Bonneville SSE
- WALLED/4th Order - ~30 cubes -
*thanks LoganBerry, CortezDVT, Cj18, SuperCharged DC, Ryan-RAM Designs,LoudNLow931*
and u have the subs wired at 1 ohm each ?
c&d batteries i can get them cheap down here
i have 5 100ah ones a 50ah one up front and a 70ah one thats my friends in back too.
no the amps are strapped at .7, i was strapped at 1.4 before and voltage never dropped below 13.
i get alot of rise from my wall.
i feel you on the rear suspension issue...i had that problem for quite some time until i made custom coilovers with springs for a hymer camper van that are rated to 4 tonnes.i now have better ride quality on the back than on the front.
'92 toy rolla EE90/AE92 1.3lt 12 x 8inch beyma (mids) 6 x beyma CP21-F tweeters(highs) 4 x 15 SPL Dynamics SPL380 D2(walled) 2 x ESX Vision 2500.2(mids,highs) 1 x SPL Dynamics D9-XS(subs) 4 x stinger SPV70 + 5 X SVR platinum 3500P batts 157.2 official on db drag comp-157.3 on same comp but eliminated...still a work in progress... Team Hxomania Trikala http://www.stevemeadedesigns.com/board/topic/156885-lil-noisy-toy-rolla/
how much did they cost you? and did you upgrade your shocks too?
is it alot less bouncy and actually stiff now?
well i don't know how much it is in dollars but mine were made like that:cut the rear suspension up took the insert off,then we got red koni inserts in.welded bolt patterns on then screwed the lower plates for the springs and reasembled them.it costed me about 320 euros to make the rear ones and most of the cost was for the springs
