Could really use some help
is it possible for a program to help design me a box for underneath the back seath of an extended cab chevy.
ive seen the programs that most people on here use but they all seem to make square boxes and that wont work for me.
ive never used any of the programs but i was jsut wondering if its possible or if anyone could help me out with this.
99 Gmc sierra extended cab
front speakers: DB drive 6.5
back speakers: DB drive 6.5
amp: none right not
subs: none right now
Future
waiting to get my 2 skar vvw 8s installed
what shape do you need?
its basically a wedge but there is a hump in the center.
here is a link to one just like it but the only difference is i have raised my seat so that i can fit alot bigger subs.
http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/2395100/vpcsid/0/SFV/30046
Edited by WICK3DxGATA
amp: none right not
Future
youd have to figureout the volume of the middle chamber then add that to the volume of the other two chambers
no ive got the area for it i was just wowndering how i could figure out how to tune it.
amp: none right not
Future
that would be the problem, because i dont know how that odd shape would affect tuning
Shape has nothing to do with it. It's still "X" amount of volume that would require "Y" port to bring you to a "Z" tuning. If you get what I'm trying to say. I don't have any dimensions to use which is why I used the XYZ as an example. You just need to break every section down into squares and add them together to find an accurate total internal volume so that your tuning comes out to what you want it to be.
Edited by loudNlow87
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
The Torres calculator can calculate for any shape, just enter the the volume before displacements in the "Desired gross volume" box enter the dimensions of the port and the subs and bracing displacements.
thanks
amp: none right not
Future
