Question Mark Posted May 7, 2012 Report Posted May 7, 2012 Will an amp that run 1kW @ 4Ohms draw less current than one amp that spit's out 1kW @ 1 Ohm? I guess it will be more heatloss at 1 ohm. Ohms law says I=U/R. The lower resistance, the bigger current? I'm looking to buy a bigger amp than I need instead of getting a bigger one when I will upgrade my system. So I thought that I could wire my subs higher so the voltage wouldn't drop as much?
Zapanater Posted May 7, 2012 Report Posted May 7, 2012 Yep, greater efficiency and less distortion. Wiring higher is always a good thing if you can. 2015 Subaru Outback. That is all, I refuse to touch it.
HHR Ed Posted May 7, 2012 Report Posted May 7, 2012 Most likely the amp at 1ohm will draw more current as efficiency drops as the impedance drops. But it depends on the amp and it's efficiency. You may have a cheap, inefficient amp doing 1000w at 4ohms and it may draw more current that a good, efficient amp doing the same power at 1ohm. So it very much depends on the amplifier quality and efficiency. Ed Lester ShowtimeSPL Host Showtime Electronics Video MarketingMy old Build Loghttp://www.stevemead...08/#entry511451http://www.youtube.com/showtimespl 5 time dB Drag Finalist Last ride 2007 HHR, current dB 153.5 and bass race 149.4 dB. 153.0 dB on music New Ride, 2008 HHR SS. Build under way. Loudest score ever = 171dB 2009 dB Drag Racing, North American Points Champion
Watch the bass Posted May 7, 2012 Report Posted May 7, 2012 Are they same amp class technic? "in the abundance of water, the fool is thirsty" Bob Marley
Question Mark Posted May 7, 2012 Author Report Posted May 7, 2012 I was thinking of this amp. It's rated 5000W at 1 ohm, 2800W at 2 and 1500W at 4ohm with 86% efficiency at 4 ohm
