Go-N-Def Posted May 7, 2012 Report Posted May 7, 2012 I have a 2003 ford exeplorer limited. To get loud what sould i use 6x8 or 5 1/4 comp . If the 6x8 is bigger but the 5 1/4 would be better speaker qulty. bigger or more qulty Quote Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
AI James Posted May 7, 2012 Report Posted May 7, 2012 cone area always applies. i wouldnt run the 5.25 in that hole. when a 6.5 isnt that hard to fit there. Quote
New2Dis Posted May 7, 2012 Report Posted May 7, 2012 i second the 6.5 idea Quote "Damned if i do, damned if i don't..."Sold to: RodeoSport, deeppinkdiver, kevosinn, CortezDTV Bought from: SlamminBeats, Carboardcat15
Go-N-Def Posted May 8, 2012 Author Report Posted May 8, 2012 i second the 6.5 idea are u foreal that what i wanted. what way do i go about it Quote Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
aN-i-No Posted May 8, 2012 Report Posted May 8, 2012 (edited) i second the 6.5 idea are u foreal that what i wanted. what way do i go about it Get some wood. Trace your 6x8 for the mounting holes. Trace your 6.5 over the markings 6x8 for the mounting holes. Cut the hole for the 6.5. The spots you marked for the 6x8 mounting holes you will put a screw through into the door just like a 6x8 speaker. Then you install the 6.5 into the hole that you cut out of the wood. You did that shit, so now finish and paint it so that it doesn't soak up water. Listen to your dope ass 6.5's. EDIT: Like this Edited May 8, 2012 by aN-i-No Quote
Go-N-Def Posted May 8, 2012 Author Report Posted May 8, 2012 type of wood can i do ply, thickness Quote Yo dog i heard you like boxes. so i put a box inside a box so you can bass while you FAIL
aN-i-No Posted May 8, 2012 Report Posted May 8, 2012 type of wood can i do ply, thickness Just use 3/4 MDF unless you wanna get fancy. I put pics in the post above to help you out. Quote
Miguels Posted May 8, 2012 Report Posted May 8, 2012 or you can always by an adapter http://www.ebay.com/itm/6x9-6x8-5x7-to-5-25-or-6-5-Speaker-Adapters-Plates-/260853369308?pt=LH_DefaultDomain_0&hash=item3cbc1289dc#ht_770wt_1163 Quote my logshttp://www.stevemead...-my-new-set-up/my blow through loghttp://www.stevemead...future-updates/ 96 ss http://www.stevemeadedesigns.com/board/topic/164094-96-impala-ss-build/
aN-i-No Posted May 8, 2012 Report Posted May 8, 2012 (edited) or you can always by an adapter http://www.ebay.com/...c#ht_770wt_1163 The problem with those is that they're made for bitch speakers...(the holes are really small) and if you try to widen it up you'll crack it. I tried that first lol.... prefferably cleaner cuts as well Meh, it's behind the door. Edited May 8, 2012 by aN-i-No Quote
