boostin302 Posted May 9, 2012 Report Posted May 9, 2012 im going to be purchasing 2 hifoinics brutus amps 2400 @ 1 ohm this weekend and running them on 2 treo 12 inch SSX. i notice on the amps theres a master and slave and from what i understand is they can be strapped to each other. my question tho is im going to be running one amp per sub and was wondering how the wiring goes for that. im mainly talking about the RCA cables. also installing a kenwood double din 318 deck if u need that info. thanks for your help and have a wonderful afternoon/evening Joshua My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/ 2001 Ford Mustang GT 4.6 SOHC 380HP 270 amp Mechman alt 2 12" Treo SSX custom built. 6.47 cu ft, tuned to 32Hz 2 hifonics Brutus 2400.1, strapped 1 optima yellow top 1 Kinetic HC1800 14.4v @ 29Hz, 2k RPM over 100ft 1/0 XS flex wire Big 3 in 1/0 100sq ft fatmat deadener 145.3 on music, 142.6 sealed on music Stop being a pussy and wall it off. I hate when my google breaks too I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines.
MrSkippyJ Posted May 9, 2012 Report Posted May 9, 2012 so are you going to master/slave the amps or not? if you are, then you aren't running one sub per amp. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
boostin302 Posted May 9, 2012 Author Report Posted May 9, 2012 no im not planning on master/slaving the amps. sorry for the confusion My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/ 2001 Ford Mustang GT 4.6 SOHC 380HP 270 amp Mechman alt 2 12" Treo SSX custom built. 6.47 cu ft, tuned to 32Hz 2 hifonics Brutus 2400.1, strapped 1 optima yellow top 1 Kinetic HC1800 14.4v @ 29Hz, 2k RPM over 100ft 1/0 XS flex wire Big 3 in 1/0 100sq ft fatmat deadener 145.3 on music, 142.6 sealed on music Stop being a pussy and wall it off. I hate when my google breaks too I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines.
vibrator Posted May 9, 2012 Report Posted May 9, 2012 depends if yours is the dual 1 ohm or dual 2 ohm. Henry Ford once received a letter from a depression-era bank robber responsible for the deaths of several law enforcement officers, killed in their attempt to stop him as he fled the crime scene. In his letter, he thanked Mr. Ford for making his Model A Ford such a good getaway car.
Guest Posted May 9, 2012 Report Posted May 9, 2012 i hope you invested a few hundred in electrical for those amps.
boostin302 Posted May 9, 2012 Author Report Posted May 9, 2012 yes im running 1/0 all the way back to 2 D3400 My build log http://www.stevemeadedesigns.com/board/topic/143943-2001-mustang-gt-system-rebuild-box-build-pics-updated-61512/ 2001 Ford Mustang GT 4.6 SOHC 380HP 270 amp Mechman alt 2 12" Treo SSX custom built. 6.47 cu ft, tuned to 32Hz 2 hifonics Brutus 2400.1, strapped 1 optima yellow top 1 Kinetic HC1800 14.4v @ 29Hz, 2k RPM over 100ft 1/0 XS flex wire Big 3 in 1/0 100sq ft fatmat deadener 145.3 on music, 142.6 sealed on music Stop being a pussy and wall it off. I hate when my google breaks too I think the usps must be ran by a bunch of drunk ass oriental midget monkey's on methamphetamines.
audio1der Posted May 10, 2012 Report Posted May 10, 2012 The Brutus amps (the bigger ones, at least) have seperate outputs from the master/slave RCA in/out. Use the RCA preamp output of your HU to the input of the 1st amp. RCA the regular output of the first amp to the input of the second amp. If, for whatever reason the ones you pick up don't have the output which isn't master/slave, just split the RCA output of the HU right before the first amp. Doing this doesn't lower the input voltage into either of the amps, it just raises the impedance a little. Big 3 with 1/0 welding cable, dual runs of 1/0 and 2gua F-R DD 2512 D2 powered by Audioque 1200d at 1ohm, 2.5ft^3 ported to 36Hz Boston SX 6.0 comps powered by Phoenix Gold M50 for front stage Silver Flute 8" midbass in doors powered by Alpine 3539 Alpine CDA-117 HU
