no it wont fucking work. there is no "it might" or "it will if you do this". it fucking wont. they're different impedances. the one with the lower impedance will get driven harder. just no.
ok, but how do you REALLY feel?
I agree ... It will not work ... too many bad variables ...
this is my best solution ...
you would be better off running 1 sub per amp ... for one amp to see a 1 ohm lod and the other sees 2 ohms ...
Might not be the "Correct" way of doing things, but you will have a better chance of not burning amps up ...
and yes, run the subs in separate enclosures please ...
or just wallsocket them and see how long they last......with vids of course!!!
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
if subs are in the same enclosure and are sharing the same airspace youre gonna have issues running them each on their own amp... being that theyll each be getting a different amount of power even if you use 2 identical amps (due to impedence) the sub getting more power will out do the less powerful sub...
BOOSH!
also i think you should get rid of the dual 4 ohm sub and get another dual 2 ohm sub. then run em at 2 ohms. i guess the obvious question here is why are you trying to run at 1 ohm if you have 2 amps strapped? sounds like a fire is gonna happen if you do.
BOOSH!
  • Who's Online   0 Members, 0 Anonymous, 2279 Guests (See full list)
