i would try aeros, that can save you a lot of room :)
Everything look ok but hz
I'm not a home to try any variations
idd drop the port size down to around 4.75 (15sqin per ft) and lower the tuning to around 33hz
Even just making the port smaller a bit smaller will lower your tuning,
Edited by john253a
so this, and how can i do interchangable port for daily and spl
03 tahoe z71
4 death penalty 18s
2 ampere audio 3800s @ .5 each
18v
156.7 @ 35hz
158.5 @ 50hz
that´s a monster box!!! Should get loud as hell, looks very similar to a box i built recently for a pair of DD 2515´s , i tuned it @ 37 hz tho, in a SUV did a 150.6 @ 44 hz using a m3 wired at 0.5 ohms
im hoping it gets loud. the box in my truck now did a 142.6 on an audiocontrol meter and if its as much as they say its off from a termlab that means im only doin in the 30s somewhere and that dont seem right. I know every truck is different but i seen a f150 with 2 american bass 15s inverted firing up, on an atomic 1600.1 (which is what i had in my truck but now i have an rd 1750.1) doing 148s on a tl and id be fine with that.
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
Install is everything man, and about the audiocontrol, it was a mic 190 or the sensor??
i don´t care that much about the score actually, i mean, a ext cab is LOUD as hell on the meter if you place subs front and port up, but for music, subs up and port side is my favorite, this shows you that sometimes scoring a better number on the meter doesn´t mean it plays nicer to your ears :)
Yeah its the ac 190. I plan on trimming everything out so it looks like everything was supposed to be there. Im trying to get used to using torres to figure everything out. Im not too worried about the score but I would like to have some fun at the comps at the shows ill be attending and do well.
03 tahoe z71
4 death penalty 18s
18v
156.7 @ 35hz
158.5 @ 50hz
Well, box measures you have on your last image should murder in that car ;)
