Running 2 ohm with a 4 ohm
I have 4 Rockford T2 15's. Two are 2 ohm and two are 4 ohm. I am wanting to run all four in a fourth order box an I am concerned because the qts are slightly different. I can wire the two 4ohm subs to run at 2 ohms. But I don't really know what problems could arise. Any help would be appreciated.
Never mix different coils together on 1 amp. Now if you run 2 amps. 1 amp for the dual 2 subs and 1 for the dual 4 that would alright. I Think.....
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
TaylorFade, on 02 Jul 2013 - 9:38 PM, said:
Go back to that place, ask to speak to that dude again, look him dead in the eye and then.... pop him in the snot box.
Tell him T-Fade sent you.
dont bother mixing different impedence woofers at all... ok it can be done, but in general its a fruitless quest.
Hammerdown... 1%
You'd need the same amount of power going to each individual woofer. You'd need at least 2 amps to do this.
These amps claim to do the same power at 1 ohm as they do at 2. So, maybe you could get two of these, and wire two of the same coiled subs in parallel on the same amp.
http://www.rockfordfosgate.com/products/product_details.aspx?itemid=117366
*New vehicle and system coming soon.*
Yeah I figured it wasn't going to work with the amp I just bought. So now I must sell two of them and get two new ones. The build will happen. Thanks Guys!
  • 1 month later...
Decided to go with 4 ohm Orion 15's. Since the rockfords won't work in a fourth order enclosure.
  • Who's Online   0 Members, 0 Anonymous, 1127 Guests (See full list)
