Also Edgar, it helps in tuning also because the subs sense/split the volume, but your port will not. It will sense 12 cubes. So in other words, your port can be shorter as well, which is an added benefit of common chambers.
there are also a few other pro/con
pros
smaller box saves space, and uses less wood, $$$ in the pocket
flattens out the response peek,
increases port efficiency, ie. 2 ports 3"x10" have a surface area of 52" but a 1 port 6"x10" is only 32"
allows a shorter port to be used,
cons
all subs must be the same identical sub
should share common power source
lower box response peek (if your chasing numbers)
box can't be split to fit into smaller areas. ie, 2 smaller boxes on each side of car, allowing access to the centre for storage (depending on sub size)
there probably are many more if forgotten,
Shorter port will be a good thing, the box is going to be shallow relative to its WxH.
I don't care if you can hear me from down the block....I just want to make sure you FEEL me from there...
I'm a swinger, can I borrow your wife for a few?
