In every single box I have built in the past each sub has had its own airspace sealed off from other subs by an internal wall. I admit I am way out of date on enclosure theory. That being said, I have seen and heard several nice systems lately and some have subs sharing airspace in the box. Now comes the questions part.
When 2 subs share the same air(for example a 6cu box with 2 subs in it) does each sub act like its in 1/2 the airspace or does it act like one sub in the whole airspace?
If 2 subs share an airspace do they fight against each other or act like one big sub?
What are the cons/pros to open chambers as opposed to each sub in its own?
I am building a box/wall in an 08 nissan frontier kingcab and am still playing with design as I try to maximize airspace and not have to move my front seats up. If I build it with seperate chambers sealed off from each other inside the box It will change how I brace for flex using the center as a main brace. If I leave the inside open (except for bracing) then how do I figure volume to correctly port? 1/2 the airspace per sub?
I really dont want to do as I have in the past with boxes and keep pulling them out and remaking them to get what I want. This needs to be a one time get it right. Retuning will not be a problem as I plan to either make a drop in or use aeros, so I just need to get the enclosure built right first.
Planning on 2 RE sx 18s. I guess what I really need to know is seperate or shared airspace in the 12cu enclosure.
Edited by ralimore
I don't care if you can hear me from down the block....I just want to make sure you FEEL me from there...
I'm a swinger, can I borrow your wife for a few?
The expression you are looking for is "common chamber" , you have always used seperated chamber, i´ve tested this myself a few times, and i LOVE how performs a common chambered box, also, you save some good internal space of the box by doing this.
Common chamber FTW hehe :)
Well I'm no pro however every box I build where the subs share air space I take recommended ported box size and multiply it by number of subs. The three boxes I've built have turned out well. Could have been dumb luck. As far as porting I also went with manufacturers recommendations.
So, does each sub "see" half of the airspace or do they act like there in the box by themselves.
Will each sub see 6 or 12 cubes?
6
good luck with the build.
(2008) Florida State Champion Bass Race 140-149.9
(2008) Florida State Champion Bass Boxing Middleweight Class
Thats what I was assuming but since this place exists I wanted to get verification. Thanks! Next step, pull all the trim and seats out of the back and get actual measurements. That and whatever I decide to use to deaden the back of the cab with..
Split airspace...got it
Edited by ralimore
