thegr8cody Posted December 27, 2007 Report Posted December 27, 2007 i sent power acoustik an email a while back and i just got to reading it this is what he said Hello, The amplifier will do 2300 watts at 14.2V at 1% distortion. The current will be 150A Reynaldo Chavez Power Acoustik Power Acoustik Att: Parts Dept. Technical Services 1550 S. Maple Ave. Tel-(800)-832-4647 Montebello, CA 90640 Fax- (323) 722-1122 now if you do the math 150 x 14.4 = 2160 at 14 volts not 12 - 13 thats at best voltage. so 2160 divided by 75% = 1620 watts at 14 volts if i did that right and thats if the amp is that efficient Quote 1998 gmc sierra h/u:eclipse cd3200 sub:dd9518g d1.5 amp:jl e300/4 sub amp:dd m2a front stage:id ctx65cs dc power 270 alt lots of kicker 1/0
AI James Posted December 27, 2007 Report Posted December 27, 2007 yup i tryed to tell peopel before but they were wanting an amp that does power at low price and didnt wanna hear that Quote
mrwigglezdj Posted December 27, 2007 Report Posted December 27, 2007 well i dont know the true power of the 3000d i dont think anyone really has tested 4-6 at one time to get a correct average, but i know my old manual for my amp said to fuse at 150 amps and that the amp will draw upwards of 190 amps at full current draw Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
IH8PunkRok Posted December 27, 2007 Report Posted December 27, 2007 u know i dont believe that the a3000db does 2000 i have it wired at 4 ohms and it doesnt seem like it pushes the cvr's like it should im thinkin i should wire it 1 ohm to see if it pushes em right Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
mrwigglezdj Posted December 27, 2007 Report Posted December 27, 2007 15s or 12s and how many, if you do 2 12s at 1ohm you might not have 12s anymore..... Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
IH8PunkRok Posted December 27, 2007 Report Posted December 27, 2007 i have 2 15's *check the sig* Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
thegr8cody Posted December 27, 2007 Author Report Posted December 27, 2007 i didnt wanna believe it cause i had it wired at 1 ohm to a btl 18 and it slammed crazy but then again its an 18 and spl of 95 so its real sensitive.but now i believe what made it so loud was the awesome box it was in (built by yours truly ) lol Quote 1998 gmc sierra h/u:eclipse cd3200 sub:dd9518g d1.5 amp:jl e300/4 sub amp:dd m2a front stage:id ctx65cs dc power 270 alt lots of kicker 1/0
mrwigglezdj Posted December 27, 2007 Report Posted December 27, 2007 i had 2 15 crvs on a 3000d and it was nice. and yea your box measn the most in an install Quote Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
AI James Posted December 27, 2007 Report Posted December 27, 2007 peopel have tested lots of them and came up with form 1200rms to 1600 rms at 1ohm on them, so i tend to believe the many many test yielding less then rated power. We had 2 here locally and they both benched under what they are rated at by alot, so to each thier own. Quote
IH8PunkRok Posted December 27, 2007 Report Posted December 27, 2007 i had 2 15 crvs on a 3000d and it was nice. and yea your box measn the most in an install dont get me wrong its loud and sounds really good doin it but when i look at the subs they dont move alot Quote -Matt2005 Dodge Magnum RTJVC KD-AVX1 2 PPI S580.2 Obsidian Audio ST1 Horn Tweeters PRV 8MB450s Audio Legion 3500.1D 2 RE MT 18s 360 ah LiFePO4 BatterySHCA 2/0 155.2 @ 29 hzKicker CVR 15's buildDD 3512e buildMini T-Line Build(6) 8s BuildNightshade 15s Wall BuildMagnum AB XFL 12s BuildNewest Magnum Build
