Power Aoustik A3000db
thegr8cody
i sent power acoustik an email a while back and i just got to reading it this is what he said
Hello,
The amplifier will do 2300 watts at 14.2V at 1% distortion. The current will be 150A
Reynaldo Chavez Power Acoustik
Power Acoustik Att: Parts Dept.
Technical Services 1550 S. Maple Ave.
Tel-(800)-832-4647 Montebello, CA 90640
Fax- (323) 722-1122
now if you do the math 150 x 14.4 = 2160 at 14 volts not 12 - 13 thats at best voltage. so 2160 divided by 75% = 1620 watts at 14 volts if i did that right and thats if the amp is that efficient
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
front stage:id ctx65cs
dc power 270 alt
lots of kicker 1/0
well i dont know the true power of the 3000d i dont think anyone really has tested 4-6 at one time to get a correct average, but i know my old manual for my amp said to fuse at 150 amps and that the amp will draw upwards of 190 amps at full current draw
Americas loudest work van2006 iasca heavyweight bassboxing champion at 150.4 db with 60second average TL8 memphis PR15s,12 memphis PR6.5's coax,4 memphis PR 1inch tweets
u know i dont believe that the a3000db does 2000
i have it wired at 4 ohms and it doesnt seem like it pushes the cvr's like it should
im thinkin i should wire it 1 ohm to see if it pushes em right
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
i have 2 15's *check the sig*
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
i didnt wanna believe it cause i had it wired at 1 ohm to a btl 18 and it slammed crazy but then again its an 18 and spl of 95 so its real sensitive.but now i believe what made it so loud was the awesome box it was in (built by yours truly :P ) lol
1998 gmc sierra
h/u:eclipse cd3200
sub:dd9518g d1.5
amp:jl e300/4
sub amp:dd m2a
dc power 270 alt
lots of kicker 1/0
peopel have tested lots of them and came up with form 1200rms to 1600 rms at 1ohm on them, so i tend to believe the many many test yielding less then rated power. We had 2 here locally and they both benched under what they are rated at by alot, so to each thier own.
i had 2 15 crvs on a 3000d and it was nice.
and yea your box measn the most in an install
dont get me wrong its loud and sounds really good doin it but when i look at the subs they dont move alot
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   1 Member, 0 Anonymous, 1584 Guests (See full list)
