Just run a second battery, cap, or distribution block and 4 gauge from there to the amp. Or run a reducer like Hotdog said.
No need for a reducer, after soldering and twisting the wires it fit the amp perfect
Well guys 0 gauge wire turned out to not be so good łøł 2 days and the battery is dead as can be going to try the 4 gauge now
i doubt thats the reason your battery is dead.......
I dont think 0ga caused your battery to die. You have another issue. Power wire transfers juice, doesnt do anything else.
1999 Lincoln Town Car-(build underway)
- (2) SA15s, 4th order, DAT 2500.1, O2 mids n highs, 250a alt, HC 2400, Big 3....
1994 Pontiac T/A for speeding tickets.-
- Currently on jack stands, wanting to be a real race car
"Your local forecast, all the ladies in the metro area should expect to see 8 inches tonight" - The Todd
Decaf, on 01 November 2011 - 02:38 PM, said:
i provide the ammo for destruction, the trigger finger is connected to the volume knob tho
URBAN GORILLA AUDIO
Well it's strange I have the 4 gauge installed in the truck now just finished now the headlights don't dim or anything so I'm confused, with the 0 gauge wire it would dim the headlights completely out, this is a kicker zx 400.1 amp RMS Wattage at 4 Ohm x 1 Channel: 200 I have never had a small amp like this to dim headlights? Let along kill a battery It would haft to be the big wire am I wrong?
Well witch of these would be best or are they both useless 1st KOLE AUDIO 300 AMP 16 VOLTS DC CAPCELL BATTERY CAPACITOR W/ DIGITAL VOLT METER
2: Shuriken SK-BT20 20 Amp Hour 12V Car Audio AGM Power Cell Battery
Or what would you recommend for a little more power other then a HO alternator
Honestly I would suggest figuring out what is wrong with your electrical. You shouldn't be dimming on 400 watts, your battery shouldn't randaomly go dead either. What brand of 0 gauge do you have.
If you are having no problems with the 4 gauge and you're wanting to add some capacitance I would go with the Shuriken.
  • Who's Online   0 Members, 0 Anonymous, 991 Guests (See full list)
