VaNQuisH Posted May 20, 2012 Report Posted May 20, 2012 Goal: .75^ft3 @35hz net I'm using tores box calc and can't get the port down under 30+ inches for this tuning and I dont want a external port. Max dimensions for width are 30inches depth and height are flexible. Should I do something other than a L-slot port. I want to build this tomorrow can someone give me a hand. Currently: * Hybrid Audio Legathia 3-Way Active Front Stage * (2) Morel Ultimo 12's * (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm) * (1) Arc Audio 1200.6 * RF 360.3 DSP
john253a Posted May 20, 2012 Report Posted May 20, 2012 this is my friends sa8v2 build thats im doing for him the drawing isnt finished as im building it and dont need it finished, i only drew it to work out port measurements
john253a Posted May 20, 2012 Report Posted May 20, 2012 How many sub and what are your other dimensions i see 30w but height and deepth as you can see you can fit these in very small areas you just need to put in the time to work it all out
Joe X Posted May 20, 2012 Report Posted May 20, 2012 Goal: .75^ft3 @35hz net I'm using tores box calc and can't get the port down under 30+ inches for this tuning and I dont want a external port. Max dimensions for width are 30inches depth and height are flexible. Should I do something other than a L-slot port. I want to build this tomorrow can someone give me a hand. Here is a box I did for a previous request : single sa8v2 @35Hz: Enclosure Specifications: Fb = 35.3 Hz Vb = 0.72 ft^3 External Height = 10 in External Width = 22 in External Depth = 12 in Port Width = 1 1/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 22 x 10 Left & Right Sides = 10 1/2 x 8 1/2 Top & Bottom = 22 x 10 1/2 L Port Internal Assembly Parts: Front to Back = 9 1/4 x 8 1/2 Extension = 16 1/4 x 8 1/2 Assembles like this:
VaNQuisH Posted May 20, 2012 Author Report Posted May 20, 2012 Goal: .75^ft3 @35hz net I'm using tores box calc and can't get the port down under 30+ inches for this tuning and I dont want a external port. Max dimensions for width are 30inches depth and height are flexible. Should I do something other than a L-slot port. I want to build this tomorrow can someone give me a hand. Here is a box I did for a previous request : single sa8v2 @35Hz: Enclosure Specifications: Fb = 35.3 Hz Vb = 0.72 ft^3 External Height = 10 in External Width = 22 in External Depth = 12 in Port Width = 1 1/4 in Cut Sheet List: * All Dimensions in Inches. * Wood Thickness is 3/4 for all Parts. External Enclosure Parts: Front & Back = 22 x 10 Left & Right Sides = 10 1/2 x 8 1/2 Top & Bottom = 22 x 10 1/2 L Port Internal Assembly Parts: Front to Back = 9 1/4 x 8 1/2 Extension = 16 1/4 x 8 1/2 Wow, thank you. I actually just came up with something about the same except I only got 1" width for the port so I might try yours instead. Here's what I came up with btw. Currently: * Hybrid Audio Legathia 3-Way Active Front Stage * (2) Morel Ultimo 12's * (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm) * (1) Arc Audio 1200.6 * RF 360.3 DSP
Joe X Posted May 20, 2012 Report Posted May 20, 2012 There is a couple of issues there and those are the vent area ratio should be kept 9:1 or below and secondly it's length, it's right at the second corner, nothing that can't be easily fixed though. The other thing is that a double baffle is not really necessary.
VaNQuisH Posted May 21, 2012 Author Report Posted May 21, 2012 How do I fix this issue. TTT. Currently: * Hybrid Audio Legathia 3-Way Active Front Stage * (2) Morel Ultimo 12's * (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm) * (1) Arc Audio 1200.6 * RF 360.3 DSP
loudNlow87 Posted May 21, 2012 Report Posted May 21, 2012 Why not go for something like this? '11 Jeep Patriot New Build Head Unit: Pioneer AVH-P3200DVD Front: Massive CK69 Components Front Amp: Massive NX2 Rears: Infinity Kappa's Subs: 8 Sundown SA-8 v2's Sub Amp: AB 450.1 XS D3100 Come on 150!
VaNQuisH Posted May 21, 2012 Author Report Posted May 21, 2012 Why not go for something like this? I don't think 30" of port will fit in that box. I'll modify it a bit thanks tho! Currently: * Hybrid Audio Legathia 3-Way Active Front Stage * (2) Morel Ultimo 12's * (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm) * (1) Arc Audio 1200.6 * RF 360.3 DSP
