* Sa-8 v2 * Enclosure Help
Goal:
.75^ft3 @35hz net
I'm using tores box calc and can't get the port down under 30+ inches for this tuning and I dont want a external port.
Max dimensions for width are 30inches depth and height are flexible. Should I do something other than a L-slot port.
I want to build this tomorrow can someone give me a hand.
Currently:
* Hybrid Audio Legathia 3-Way Active Front Stage
* (2) Morel Ultimo 12's
* (2) Arc Audio 1100.1 XDi v2 (Strapped @1ohm)
* (1) Arc Audio 1200.6
* RF 360.3 DSP
Goal:
.75^ft3 @35hz net
Here is a box I did for a previous request : single sa8v2 @35Hz:
Enclosure Specifications:
Fb = 35.3 Hz
Vb = 0.72 ft^3
External Height = 10 in
External Width = 22 in
External Depth = 12 in
Port Width = 1 1/4 in
Cut Sheet List:
* All Dimensions in Inches.
External Enclosure Parts:
Front & Back = 22 x 10
Left & Right Sides = 10 1/2 x 8 1/2
Top & Bottom = 22 x 10 1/2
L Port Internal Assembly Parts:
Front to Back = 9 1/4 x 8 1/2
Extension = 16 1/4 x 8 1/2
Assembles like this:
Goal:
.75^ft3 @35hz net
Fb = 35.3 Hz
Vb = 0.72 ft^3
Cut Sheet List:
Wow, thank you. I actually just came up with something about the same except I only got 1" width for the port so I might try yours instead.
Here's what I came up with btw.
Currently:
* RF 360.3 DSP
There is a couple of issues there and those are the vent area ratio should be kept 9:1 or below and secondly it's length, it's right at the second corner, nothing that can't be easily fixed though. The other thing is that a double baffle is not really necessary.
Why not go for something like this?
'11 Jeep Patriot New Build
Head Unit: Pioneer AVH-P3200DVD
Front: Massive CK69 Components
Front Amp: Massive NX2
Rears: Infinity Kappa's
Subs: 8 Sundown SA-8 v2's
Sub Amp: AB 450.1
XS D3100
Come on 150!
I don't think 30" of port will fit in that box. I'll modify it a bit thanks tho!
Currently:
* RF 360.3 DSP
  • Who's Online   0 Members, 0 Anonymous, 1537 Guests (See full list)
