Can someone just quickly verify what this box is tuned to. I tried to use Torres but got confused because there are 2 ports. thank you
2006 Jeep Grand Cherokee LaredoPioneer AVH- 3200DVD2/0 Flex-A-Prene Welding Cable
(2) Fully Loaded Fi Sp4's dual 1-------> My YouTube Channel <-------
Needs more power those woofers will laugh at that turd
Declare a port 10" in torres, add as bracing the wood of the non common wall of one of the ports + other bracing displacement. I say you are tuned higher than 34 but didn't do the math.
I think it's either double width or double length of the port IIRC.
CVX can you modify this for me while keeping the design ?
I'd have to start from scratch at this point. max dimensions, sub, power, vehicle and i'll see what i can do.
Edited by 412 CVX
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
height 14, depth 36, width 42, dc lvl 5 into bonneville trunk, 2200 watts
i'm not a fan of upward firing subs in a trunk, but try this.
do a couple vertical dowels a few inches behind the sub cutout.
a 45 along the bottom in the back, and a 45 in the rear corner opposite of the port opening.
More box builds
