Amart88 Posted May 21, 2012 Report Posted May 21, 2012 Well I've been thinking. I have 2 n2 15's (dual 2) in a wall on 2 BC3500's If I get 2 more 15's would I need to get dual 1's and recones for my dual 2's to make them 1's? and can you mix the n2 series with the old ufo's? Thanks. Just weighing my future options My 2005 s10 blazer build. 4 zcon 18's walled.
SilveradoGoesBang Posted May 21, 2012 Report Posted May 21, 2012 If your running the 2 bc at 2 ohms strapped you need four d1s the same if you run 2 on 1 bc. So yes you need d1s and not sure about the n2s and old ufos but i doubt it. "SilveradoGoesBang" http://www.stevemeadedesigns.com/board/topic/155256-silveradogoesbang-box-done-take-notes-on-bracing/ 2 FI BTL 18's CT Sounds 7k 2013 MidwestSPL Finals Xtreme 3 - 1st Place
john253a Posted May 21, 2012 Report Posted May 21, 2012 If in common chamber box then all need to be the same ohm, you amp is what will determine weather you need duel 2 or 1 ohm
Nate Futuristic Posted May 21, 2012 Report Posted May 21, 2012 They will not mix...different displacement and power handling... talked to Scott about this same question and he advised not to mix different generation subs. Better off buying n2 motors if you can find them and recones and baskets from fi... or just buying 2 more n2 dual 1s from them along with recones for the current subs you have... down rpping vanderbilt. 30 miles from victoria. i own the 3rd loudest setup here out of 3. but i did put together all 3 setups ^^ Cant wait to swalllow Ghost's babies
