I have a Hifonics Brutus 1600.1 wired to a half ohm, (before box rise), and four CVR 12s In a 10^ft box after displacement tuned to 35 hz. What should I set my subsonic filter, lpf and such at and why.?
Current setup in my 96 Hoe
Hu - Pioneer DEH-80prs.
Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets)
Batts - 4 91ah rear batts, 50ah batt up front.
Subs - 2 Crossfire XSv2 18's
Alt - Singer 330A
Front stage - Random JL & Eclipse mids, Eclipse tweets
low pass filter-80hz
sub sonic filter-30hz
you dont wanna have your sub sonic filter lower then that because the low pass filter plays a part in it as well.
gain-depends on your head units pre out volts
bass boost-OFF
bass boost-OFF
everything is correct, but wat (bolded)?
shouldnt have to go anymore then halfway on the gain. usually 1/3-1/2 on gain is appropriate as a generalization
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
doesnt the low pass filter play a part in the lows as well? low pass filter normally start from 20hz so if it is set at 80hz it will play 20 to 80hz?
If you set it to 80z it blocks frequencies above that. Whatever is below it plays, its not to set up a certain range of frequencies.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
