What should I set my amp settings to ?
I have a Hifonics Brutus 1600.1 wired to a half ohm, (before box rise), and four CVR 12s In a 10^ft box after displacement tuned to 35 hz. What should I set my subsonic filter, lpf and such at and why.?
Current setup in my 96 Hoe
Hu - Pioneer DEH-80prs.
Amps - (4) Crossfire C5 1700D's, MTX Thunder 5604(mids), PPI Art 300.2 (tweets)
Batts - 4 91ah rear batts, 50ah batt up front.
Subs - 2 Crossfire XSv2 18's
Alt - Singer 330A
Front stage - Random JL & Eclipse mids, Eclipse tweets
low pass filter-80hz
sub sonic filter-30hz
you dont wanna have your sub sonic filter lower then that because the low pass filter plays a part in it as well.
gain-depends on your head units pre out volts
bass boost-OFF
everything is correct, but wat (bolded)?
shouldnt have to go anymore then halfway on the gain. usually 1/3-1/2 on gain is appropriate as a generalization
Team NWSPL
baaudio Build Log
2001 GMC Sierra walkthrough
4 Mechman Elite 370s, 10 AGM batteries, 3 Crossfire XS v2 18s, Crossfire 8k
If you set it to 80z it blocks frequencies above that. Whatever is below it plays, its not to set up a certain range of frequencies.
And the fact more than one person agrees does not make it a circle jerk, it makes it a bukkake scene and you're in the middle ;)
Chick took 3 shots of Jager, and then, pissed in my mouth..
B5 Passat Build Log
