quick questiong about power
I know there is a lot of diffrent opinions about this matter but if you under power a subwoofer in a sealed box could it ruin the subwoofer? As in running 150-200rms to a 750rms dvc subwoofer?
1998 Pontiac grand prix gtp supercharged2 12" Obsidain Audio V.1 on a 2011 zx1500.1 at 2 ohms. 20ft of Knuconceptz CCA 0 Guage. 2nd Battery is a Shurken BT-120. Box is 3.5cu tuned at 31.8hz sealed off from the trunk. 14sqft of Dynamat on the Rear deck top & bottom. Soon to be more for doors/roof. Gets low & loud
Did a 140.5 Sealed at Battle of the boom in June 2013 dropping to 12.7v (need a alt mines going bad)
i dont understand the question? are you asking if its bad to do so?
04 dodge dakota ext cab 4x4
excessive amperage 300 amp alt with MONSTER stud =)sundown z v3 15 in a 4th order on aq2200sundown 100.4 2 way active...2 Prv audio 6mb200 & 2 re XXX tweetersdeka intimidatorkenwood x396big 3 1/0 knu wire back to deka intimidator
If under powering a subwoofer can hurt it, then every time you don't play you stuff at full tilt it could blow.
F150:
Stock :(
2019 Harley Road Glide:
Processor: DSR1
Lid (Rear) 6x9s -  TMS69
yeah pretty much. so theoretically every time you lower the volume, your stuff will blow.
it wont happen. only reason things blow when being under powered is because stupid people crank settings up and cause the amp to distort cause they think it should be louder.
yea it is crap i use to think so but then my sub should have blown years ago so no it doesn't ruin the sub
i had about the same thing to two subs about 200 each stupid screws were junk that i used though box was junk also stripped a screw hole out and broke two and i was wondering why it wouldn't seal lol
skar sk2500.1
0 gauge power and ground kunukonceptz
alpine HU
vxi65 components on BA gt-275
new build log -> http://www.stevemeadedesigns.com/board/topic/150642-project-d-kon-deathcards-build-log/#entry2148821
2 x-15 sundowns
singer alt, odyssey bat, and maxwell ultra caps
you makea good pount you can never hurt a sub by under power.... way to blow sub are unclean power and over powering the sub or worry box size
2003 Grand AM GTELECTRICAL SYSTEMAlternatorstockBatteryFront s3400back d3100Wireinglots of 0gaHEAD UNITpionner 7500xSPEAKERS(4)Prv 6mb200(2)prv 10mr1000AMPLIFIRLS(1)Zxi80.4(2)Brx1200.4SUBWOOFER(2) MTX 9500BOX3.41 cuft 63sq port 34hzLINKSYoutube.com/reggieb198895
Oh ok, was just wondering cause I got a 250watt amp now wired up, & I got a 1500rms amp waiting to be put in after I run my 0 guage but won't have time for a week or so.
  • Who's Online   0 Members, 0 Anonymous, 1068 Guests (See full list)
