Best way to cover that sub 30 hz range
IH8PunkRok
im going to be trying a modest sq system
i want to try 8s for the substage
they will play only 20-55 hz
the front stage will handle the rest
however i want it to be flat. all the way down. is there a good way or rather a proven way to keep those sub frequencies from dying out with little speakers?
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
i have bassbox which i trust more than winisd
why do you recommend the epic?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Low fs, high xmax, models well at least in WinISD, I've heard great things about their SQ, and can say with experience with the 10" version that they are very clean sounding subs.
*New vehicle and system coming soon.*
Well here Is the thing. I do believe that with the high xmax it can handle the lows like I need it to but I'm not completely convinced.
I could get two tang bands for the same price and I know those perform
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
its giving me interesting results. but ported is still coming out on top
the problem im having is vent velocity
i have a confined space to work with. about .8 cubes per sub (i have little pockets i want to fill up in the back)
and in order to get the tuning low enough i need to use a very small port. which causes massive vent velocity ie port noise
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
Why do you want to play that low if you are after sq
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
i want every frequency to be played
i thought that was the point?
-Matt
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
2 RE MT 18s
SHCA 2/0
155.2 @ 29 hz
DD 3512e build
Mini T-Line Build
(6) 8s Build
Newest Magnum Build
  • Who's Online   0 Members, 0 Anonymous, 1023 Guests (See full list)
