MD7786 Posted May 24, 2012 Report Posted May 24, 2012 Dustcap was real hot after bumpin for a bit. How do iI fix? DD1 only solution ?? I set amp with dmm
HunterJohnson Posted May 24, 2012 Report Posted May 24, 2012 lol make sure ur signal is clean and you need to let your subs chill if your giving over rated Scion tC SQ BuildiPad mini, lots of fabrication, daily drivenFord Explorer C Pillar Wall Build Just a cheap car to destroy with bass
SnowDrifter Posted May 24, 2012 Report Posted May 24, 2012 Did the subs stink? if not, you are fine. It's normal for subs to get warm What amp? What sub? And a DMM isn't accurate. Where are you located? A fellow member might have a dd-1 near you. http://www.stevemeadedesigns.com/board/topic/137758-smd-audio-tools-map/ ~~~~~~~~SAY NO TO PHOTOBUCKET~~~~~~~~ Snow's DD-1 tracks here: https://www.stevemeadedesigns.com/board/topic/167433-snows-dd-1-tracks/ My take on OFC vs CCA: https://www.stevemeadedesigns.com/board/topic/110381-things-that-piss-you-off-in-the-car-audio-world/?do=findComment&comment=2461444
MD7786 Posted May 24, 2012 Author Report Posted May 24, 2012 I'm in Amarillo,TX. Its a rebuilt psi 15 rated at 1200 rms on a jl 1000/1 amp.
Noel989 Posted May 24, 2012 Report Posted May 24, 2012 Double triple check wires connections from back to front one by one my sub didnt get hot only my amp and it was a bad ground it wasnt hooked im it was just touching metal and i tought it wasnt wires Build Log - http://www.stevemead...-cruiser-el-pt/
