copper nuts and bolts
Anyone ever found copper nuts and bolts? I'm trying to figure out the best way to connect a direct connect sub to an amp through the enclosure. I was thinking about running 4 nuts and bolts through, connecting the sub inside the box, then being able to connect the amp to the outside of the sub box, any thoughts or opinions on this will be greatly appreciated. The main goal is to not loose any power.
Use brass, check out , mc master Carr.com
TEAM SOUNDQUBED -- TEAM SOUTH
TEAM S.O.B. - Founder & Captain
3x Streetbeat World Record Holder
2017 MWSPL 1st place Mayhem & 4th Xtreme 4
2016 MWSPL 1st place Mayhem/2nd Adv 4/2nd Xtreme 4
2015 MWSPL 2nd place Mayhem & 4th Xtreme 4
2014 USACI 2nd place Streetbeat 5 - 162.6 db
2014 MWSPL 2nd place Xtreme 4 - 144.9 db
2013 USACI 1st place Streetbeat 4 - 161.9 db
2013 USACI 1st place Street Q+ - 162.8 db
2013 MWSPL 3rd Kaos2 & 4th Xtreme 4
2011 USACI 2nd place MOD 1001-2k - 160.0 db
2011 MWSPL 4th place: Adv3 - 157.8 db, Kaos2 - 150s db, Xtreme4 - 140s db
2010 ARSPL 1st place 501-750 - 160.3 db Arkansas loudest
Best score to date 164.4 db - Termlab Outlaw
MWSPL on Dash Legal door open (Music) - 162.5 db
Sealed on dash Legal (Music) - 161.1 db - Termlab
THE BLACK NASTY CURRENT BUILD & FAB
The Black Nasty (6) 15 Rebuild Log 2012
(4) 15 Walled Sierra Build Log
Evo X build log
Facebook page The Black Nasty
They don't have 5/16 bolts in brass so I order from mcmaster.
Evo X build log
ami you should know brass is a horible conductor... zinc is better thats your common bolt metal..
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Zinc is barely more conductive but pure zinc not plated, pure brass is better solution IMO, look at stinger ANL fuse holders, the studs are brass.
Evo X build log
brass is very corrosion resistent thats why its used so much...i actually had brass bolts going through my box a few months back..but i deleted them and just drilled holes and ran straight wires,,using average power i dont think you will see a difference either way.
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
I noticed that about the Stinger stuff, they do use brass.
But I also noticed that Kinetik and XS Power supplies stainless hardware with their batts.
So this had me wondering the same thing... Which is better?
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
  • Who's Online   0 Members, 0 Anonymous, 1129 Guests (See full list)
