copper nuts and bolts
Anyone ever found copper nuts and bolts? I'm trying to figure out the best way to connect a direct connect sub to an amp through the enclosure. I was thinking about running 4 nuts and bolts through, connecting the sub inside the box, then being able to connect the amp to the outside of the sub box, any thoughts or opinions on this will be greatly appreciated. The main goal is to not loose any power.
Use brass, check out , mc master Carr.com
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
They don't have 5/16 bolts in brass so I order from mcmaster.
Evo X build log
ami you should know brass is a horible conductor... zinc is better thats your common bolt metal..
TEAM DC AUDIO
VEHICLE:98 chevy tahoe 2wd 3-4 drop
HEADUNIT:alpine 9886
PREAMP:arcaudio
FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door
KICKPANELS:jl audio 5 1/4
REAR DOORS: dd components 6 1/2s
HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors
SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV
SUB AMP: 2-dc7.5s
ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
Zinc is barely more conductive but pure zinc not plated, pure brass is better solution IMO, look at stinger ANL fuse holders, the studs are brass.
Evo X build log
brass is very corrosion resistent thats why its used so much...i actually had brass bolts going through my box a few months back..but i deleted them and just drilled holes and ran straight wires,,using average power i dont think you will see a difference either way.
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
I noticed that about the Stinger stuff, they do use brass.
But I also noticed that Kinetik and XS Power supplies stainless hardware with their batts.
So this had me wondering the same thing... Which is better?
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
  • Who's Online   0 Members, 0 Anonymous, 1573 Guests (See full list)
