OK so today i was going to install my 4 chan amp and new door speakers till i got punched in the face by alternator wine.
So i have ruled out my speakers and amp by hooking up a iPod straight to the amp. now as soon as i plug in the rcas it wines really bad and if i unplug the reas from the head unit and only plug them into the amp it wines a very small amount but it is still there but i could live with it.
So i tried grounding my rcas to the head unit with no luck so i am confuse and pissed off at this point. what can i do next.??
I know the main source of wine is coming from the HU and a small bit from the rcas ( also the rcas are top of the line knu and i also tried my RF twisted)
any help will be helpful!!!! AHAHA
2003 VW Jetta Wagon AA Mayhem 15's Flatline BA2 2 XS D3100's in rear Shuriken BT80 under hood
Mike Singer 250A SHCA and KnuKonceptz wire Big 4+
AQ / Dayton pro mids+monsoon tweets
My Build : http://www.stevemead...35#entry1989435
Make your ground bigger at the head unit.
TEAM SOUNDQUBED -- TEAM SOUTH
Evo X build log
Facebook page The Black Nasty
http://www.youtube.c...e1?feature=mheehttp://www.stevemead...87#entry1993187
JVC KD-R530 head unit
VVME INNO-D1500 sub amp
Kenwood KAC-8402 amplifierPioneer 2-way 6.5 X2 @ 4 ohms
DTI Audio 6.5 X2 @ 4 ohmsbox: 4.24 ft^3 tuned to 61 hertz (port walls fell off and dissapeared :( )
i just had to replace set of rca's for exact same reason..prob only 6 months old rca's
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
well the rcas and power wire are ran on the other side of the car. and i have now tried 4 different rcas with the same conclusion. so it must be the ground. but i have been looking and can not find a good place to ground it.. i have a 2004 VW jetta and if know about newer vws everything is hidden or covered ect.
so i really don't know where to ground it.
damn today really pissed me off... first time where i spent 8 hours working on my audio and now am further back then i start.... Uhhh just rating
This can be one of the most difficult problems to track down and eliminate. Keep in mind, your RCA cables are likely run along the body of the car under the carpet . . . the body being the return path for all things electrical. The fact that they are on the opposite side that the power wire is run could either be helping or counting against you.
Really obnoxious noise is usually quite easy to eliminate. That typically indicates a problem with a component. Your explanation above is somewhat unclear. Did you say that you unplugged the RCA cables from the INPUT of the amplifier AT the amplifier and plugged your iPod directly into the amplifier and still had noise? Or, did you mean that you plugged your iPod into the RCA cables at the front of the vehicle near the deck?
Be careful unplugging and plugging RCA cables with the amplifier powered up. In some cases, the input section of the amplifier can begin to oscillate with nothing plugged into it. Bad things can happen as a result . . .
Tony Candela - SMD Sales & Marketing
Email me at [email protected] to learn about becoming an SMD Partner!
Upon re-reading your posts, is it possible that you did not ground the amplifier properly before powering it up? If so, the amp may have sought ground via the shield of the RCA cables and damaged the preamp section of your source unit.
